N4ADE
anyone know of any usb devices that are good for recording 5 or more scanners something that is cheep
around $100 or less preferably?
Has anyone been using these on a scanner? I bought the 3-pack off ebay. They work nicely when used as they're supposed to be (with a mic) attached. However, when I attach a scanner (headphone or speaker out) even with the volume down to nothing on the scanner, there is a bit of hum and the (AGC??) sound card is fighting me. Sounds to me like an impedance mismatch. Any cheap fixes for these cheap devices that anyone is using?
...bought a couple dozen audio transformers. I wired them in a step-down configuration since I am using speaker out from the scanners and feeding that to mic in of the sound cards. I have the volume on the scanners set to about 10:30 and the input sliders on the computer set to about 50%. The exact setting depends on what/who you are receiving though.
All the headphone jacks on scanners I have are wired so that the user can plug in a stereo or mono headphone and both sides will function. To do this the ground (sleeve) of the headphone jack is wired to ground through a resistor in the scanner. This causes a ground loop and can cause a hum or crosstalk. If all you have is a headphone jack, you may be able to eliminate the problem by using a ground from the external power supply (which is powering the scanner) or the antenna.
Ground loop isolators will help you if you have a ground loop. But they are not magical and often there are still some other ground paths. Some people have had good luck with those $16 transformers from Radio Shack. I did not want to do that for as many scanners I am an using.I know many people use the generic car stereo ground loop isolators, but in my feeds they don't always seem to work.
I made a point of saying I went to a surplus store because the transformer is not critical. You could use a 600:600 telephone line transformer and most would work fine. I found some transformers designed for audio with a 10:1 ratio. These would drop my signal by a factor of 10 to 1, which is what I wanted to do to get the signal closer to microphone level from speaker level.Can you tell us exactly what 'audio transformers' you bought and how you wired it all up?
The bulk of the scanners are PSR-400s but also have some BC780XLTs. If I connect to the headphone jack - hum, if I use EXT SP no hum. The headphone jack from a BC3000XLT worked fine, but all other scanners are base models.What scanners do you have?
I don't have one of those scanners presently, or a schematic for it. So I am uncertain about that model.I have tested your theory on my BCD996s and it doesnt seem to make a difference
I am one of them. I do notice better quality sound from the PSR-400s; of my two feeds to RR one is from a PRO-433 and the other a BC780XLT.I know there are people out there using the $1 USB 3D Audio devices and have eliminated any background noise and have a crystal clear feed when no voice is present.
I did not find that info useful. There are two ways I approached the problem, the first is to determine if the "ground" side of your audio output jack (whichever one you use) is in fact GROUND. Take an ohm meter and measure resistance to antenna ground, external power ground or a known device ground. If you get more than a few ohms (10 is way too much), connect the good ground to the ground of the audio feeding your computer.I have tried all the suggestions in the Live Audio Wiki from RR.
My first thought - are you sure that screw on the back of the scanner is a scanner ground? What sometimes seems like should be ground may not be.Since I am using the USB sound cards and removing the plastic casing - can I solder a lead on the USB sound card PCB at teh mic jack gound terminal and run the lead to a screw on the back of the scanner - will that cure all?
I was generalizing, but you're right - I am not sure.My first thought - are you sure that screw on the back of the scanner is a scanner ground? What sometimes seems like should be ground may not be.
My solution for the REC out jacks was the audio transformer circuit inline (cutting a shielded audio patch cord in half and soldering in the transformer.) For the speaker and headphone jacks I am putting in a 40db attenuation circuit too.The problem: there is no direct ground on the headphone jack on many scanners. One solution: use audio from the headphone jack as the 'hot' signal; use a good ground as the ground side of the signal (from the antenna, external power connection, etc). Do this at the radio end so that the audio is somewhat shielded between the scanner and the sound card mic input.
I made my own cables, with a transformer, too. I used stereo plugs for each end but did not wire the ring (only tip and ground). The scanner is a mono signal anyway, and I am feeding them to a mic input (mono) on the computer side..
You could try to move the attenuation right to the jack. If you are picking up noise between the transformer and the card, putting the attenuator resistors right on the jack would reduce that noise.I am using the following circuit with shielded cable for my audio, but the feeds are still not crystal clear. Provides 40db attenuation. Any suggestions to clear up the audio any more?
Final configuration is the following...
Isolation: 1Kohm shunt to ground for noise isolation (photo 1)
Ring +5: remove center ring connection from jack to prevent voltage feed into audio path. (photo 2)
[Use Radio Shack Attenuating cable if level adjustment is necessary.]
This was the best I could do.
Just to be sure I'm understanding the process here....the 1K ohm resistor is between the tip and ground?
I'm working on a project, and want to incorporate this, but need to be sure first.
