Adenosine
I would like to start a second feed. If your scanners do not alpha tag, is there a way to use scancast (Edit: running ScannerCast) to broadcast with right a left, then have RR put it up as two separate feeds?
What is the best recommendation? Do I need a different program?
My computer has onboard 5.1 audio, line in and mic in. I understand mic in is undesirable so I was intending to avoid this.
Thank You
Thank You
