dispatcher307
I've tried emailing K1PGV (Scannercast author) twice in the past three weeks but haven't gotten a reply, so I'm hoping someone else can help me.
Here was my original email:
I'm using your software in conjunction with Radio Reference and I've run into a problem I can't find a fix for. It's been running for about a week and a half with no problem. Then last night I ran into a weird problem. I couldn't connect using my BlackBerry program BBScanner. It said the scanner was offline. I went to the Radio Reference site and it came up fine and I was able to listen. I thought that was odd because I could get nearby scanners, just not my own. I was out of town so I figured I'd worry about it when I got home.
This morning I wake up and I had emails telling me my feed had gone down but later had come back up (there was no power or internet outage). I logged in remotely to my computer and the program was running. I decided to shut it down and restart figuring there might be an issue and that would resolve it. I went to restart the program and I got the attached error. I did some searching on your site, Radio Reference and Google but I couldn't find what the problem might be.
I was running .NET Framework 2.0. I did a repair on it and still got the same error. I also updated to 3.0 and I'm still getting the issue.
If I hit continue, the program will start but I am unable to select a "sound input" under the Audio section (the box is blank). If I try to start the broadcast anyway, I get another error message (see attched - ScannercastError1)
I also tried unloading the files again from the original ZIP download thinking something may have gotten corrupted but that didn't help either.
I've also attached a pic of the file folder showing everything seems to be there.
Do you have any idea what the problem is or how I might fix it?
Thanks.
Wes
Thanks.
Wes
