| Streaming / Broadcasting / Audio Recording Interested in putting your scanner online for others to hear? Want to listen to other radios on the internet. This forum is here for you to discuss these topics related to streaming scanners online. |
07-12-2011, 7:51 PM
Originally Posted by ProScan
I just released a new version. It had a bug with the GRE/RS scanners metadata tags not in sync with the audio.
It also has a test tab with a few little extra things such as a test tone generator, loopback control, and display of the scanner data.
Great update. I'm the guy with the Pro 107 that's been hoping for alpha tag support... Interestingly, the tag data is displayed in the new "Scanner Data" box. The data I'm hoping to broadcast is listed next to "Group:" Is there any possible way you can capture and broadcast this text using a new scanner model? THIS WOULD BE AWESOME!!!
07-12-2011, 8:30 PM
Email me so I can get additional info and send you out test file(s) when I do it.
07-12-2011, 8:52 PM
Email sent. THANK YOU!
07-12-2011, 9:50 PM
Got it. It may be after the next version of ProScan is out. Not sure yet.
07-22-2011, 7:54 AM
Need testers - PRO-18, PRO-107, PSR-700, amd PSR-800
Email me and I'll send you the latest file.
07-22-2011, 8:05 AM
DB Admin
I hate to be pesky by asking again, but any news on tag support for the 310/410 models?
07-22-2011, 9:23 AM
I'm definitely willing to test. Email sent.
07-22-2011, 4:44 PM
I didn't remember this. I always like suggestions via email so I can find them all in one place and when it's time, email out preview copies.
07-22-2011, 6:16 PM
DB Admin
Hmm, you posted a reply to me back in March that you were going to add 310/410 tag support to the to-do list, hence why I asked again in this thread. Not a big deal, I just sent you an email about it, thanks!
07-25-2011, 10:20 PM
Thanks for the testing. I just released the official version of RadioFeed with Pro-18 and Pro-107 support.
07-30-2011, 1:32 AM
Is there a way an auto start up when windows starts option to be added? power failures kill me here...
07-30-2011, 1:47 AM
Couldn't sleep, thought I'd check the new posts from RR, saw your question..I've looked at the RadioFeed Wiki and thought I'd seen that question...
" * How can RadioFeed automatically start streaming after the computer reboots?
Add a RadioFeed shortcut to the Windows Startup Group. Insure that the option is checked "Start Up - Source Client & Web Server Use Last State When Program Closed".
Good Luck!
07-30-2011, 2:06 AM
Ok cool! I'll set it up.
07-30-2011, 11:17 AM
You know, you really should have any computerized equipment on a UPS (Uninterruptible Power Supply). Even the little 350 or 500 Watt jobs made by APC are enough to carry you through the frequent power glitches that you might not even notice, but that can scramble the brains of your computer.
The best $40 you've ever spent, trust me.
08-07-2011, 8:34 PM
RadioFeed New Version 1.13
This is a small version upgrade but is beneficial if running a PRO-106, PRO-197, PSR-500, or PSR-600 scanners as there was a problem with the text tags.
The only other change is the addition of a connection grid in the Web Server feature showing connected media players.
At this time, there are no known bugs or issues.
RadioFeed contains a Source Client and a Web Server. The Source Client can replace Edcast/Oddcast and SimpleCast type of programs for streaming to RadioReference, Icecast, and Shoutcast servers. The Web Server is a server and does not require an external server.
08-08-2011, 10:07 AM
1. copy your shortcut to radiofeed on your desktop.
2. click on start menu
3. click on all programs.
4. find the startup folder
5. right click on startup folder and click paste.
This will make radiofeed auto start on windows startup.
Just go to radio feed options and make sure last known state is selected.
08-08-2011, 10:18 AM
DB Admin
Still no tag support for the 310/410.
08-08-2011, 10:32 AM
Try selecting the scanner type to PRO-106, PRO-197, PSR-500, or PSR-600.
That should work as I believe the 310/410 uses the same protocol and display appearance as the scanners above.
08-08-2011, 10:53 AM
DB Admin
Already tried that with both RadioFeed and ScannerCast, no dice. I do get some stuff flashing in the Scanner Data window, but it never shows up on the metadata tab, nor do the Scanner Data or Channel Active indicators ever light up.
It works fine with my BC346XT, however.
I do not believe the 310/410 display protocols are the same. Remember, the 310/410 have an additional line on the LCD compared to the older GRE models. Win500 and PSREdit had to be rewritten to support the 310/410 because of the differences.
08-08-2011, 11:02 AM
It will be a while before I can get to this. I will be focusing on the ProScan next release.
