Old 06-19-2011, 2:58 PM
Send a message via AIM to whgwvscanner Send a message via MSN to whgwvscanner Send a message via Skype™ to whgwvscanner
Default Recording your feed
So what does everyone nowadays use to record their live audio? I have been looking at an application called Total Recorder. I have used am application before called Scanner Recorder Pro also.
Things that I look for:
- Schedule - this is huge
- Auto name the file per day
- VOX would be nice - or something that could track the time a tone-out is sent
Right now I'm demoing a few different software and hopefully I can find a good one.
My system is Windows 7 x64 w/ 8GB RAM and Audio In.
Old 06-19-2011, 3:10 PM
KB3SJV's Avatar
RR automatically records all of the live audio feeds.
Live Audio Feed Provider: http://www.radioreference.com/apps/audio/?feedId=8337
Old 06-19-2011, 3:18 PM
I think RR only keeps 1 or 2 weeks of audio available. I'd be interested in jroth's demo results.
Old 06-19-2011, 4:22 PM
RR does kieep audio but it doesn't cut out dead space, only does 30mins at a time. ect
Old 06-19-2011, 6:22 PM
Location: Middleville, MI-Barry County(Near G.R. & Ionia)
Send a message via ICQ to Skud Send a message via AIM to Skud Send a message via MSN to Skud
I use IDTrackerIII. While I love it the only downfall is it reads the scanner so I cannot send alphatags to RR.
Cuts out dead space, I can set it to start a new file every so many minutes and if I lose power, I don't loose the file like some other programs do. I forgot, for the most part you need a Uniden 396/996 or PSR-500 or 600 or the radio shack version. It does not listen on the sound card to record, the scanner tells it to.
PSR-500 | PSR-310
Barry County Scanner http://barrycountyscanner.com
GRPD Scanner http://www.grandrapidspolicescanner.com/
Old 06-19-2011, 9:07 PM
I'm using Grecom scanners.
Old 06-20-2011, 8:58 AM
I like the overall quality of Total Recorder so far - I just need to find out how I can create a schedule and then auto-save that schedule daily.
Old 06-20-2011, 9:21 AM
Well, I created a schedule and I am going to run some tests today. Programs seems to do a lot - missing some features but I may be able to deal with it.
Old 06-21-2011, 5:01 AM
SlipNutz15's Avatar
Send a message via ICQ to SlipNutz15 Send a message via AIM to SlipNutz15 Send a message via MSN to SlipNutz15 Send a message via Yahoo to SlipNutz15
I use ScanRec Pro. I broadcast two scanners from one PC so obviously I have two sounds cards. ScanRec Pro allows VOX Recording from MULTIPLE sources. It was well worth the small donation I paid for it.
Once I set up the profile for each audio source, I saved them and added the profile shortcut to my startup folder. I also have my scanner PC auto-login if the power bumps or it restarts for any reason. All the scanner feed programs auto start as well as the recorder programs without me having to worry about checking on it daily.
Gregory J. Stottle KB3THR
http://www.centralpascanner.com
Old 06-21-2011, 5:54 PM
I use Proscan, saves each comm in it's own directory, sorted by date and time, only records when the scanner has activity. And I have a batch file using winrar that runs at midnight each day to archive that days recordings and empty out the directories for the next day.
Also does my RR feed with my alpha tags and I use it to program my scanner
996XT
Old 07-19-2011, 10:19 AM
I have my own scanner website. I record (archive) the stream on a linux box using a nice little script call icecream.
icecream!
This has been working great for me for well over a year now.
