W8RMH
Feed Provider Since 2012
Greetings, I have my feed working now and it's sounds great, a lot better than I anticipated. I do however have a related question.
My live scanner audio comes through on the left channel of my PC. When listening to my stream I get the usual delay as well (just to check quality, I don't normally listen to my own feed at home). It can also get confusing when listening to other feeds.
Is there a way to stop the live audio to my left channel either using my PC or the scanner? I use the record-out jack to the line-in on my sound card so I "can" listen to my scanner live.
I am using a BCT15 through a Dell desktop with 1 shielded RS cable and Scannercast. I am knowledgeable about scanners, but my computer skills are somewhat limited. Thanks.
