I’ve been trying to get Darkice working with Ubuntu 10.04 LTS. I’ve been 100% Linux (other than radio programming) since 1997 and have battled many problems, but I’m going nuts with this one! I’ve confirmed my line in and microphone jacks work. I tested the cable. I confirmed my device names and aliases. I’ve used every configuration imaginable. I can even get VLC to stream with no problem. At this point I suspect it is a Pulseaudio problem.
With that said, my question is has anyone gotten Ubuntu 10.04 and Darkice to work correctly? If so, can you share your darkice.cfg and your soundcard list?
My next step is to look at setting up a Slackware or Freebsd machine where I can be confident it is not a Pulseaudio issue.
