  #2301 (permalink)
Old 03-01-2014, 10:18 AM
Originally Posted by DC31 View Post
The following note came from one of my users:
I just uninstalled the google play music update and your test page is now working. I guess the play music update is the problem. I installed it back to the original factory setting.
The update seemed to be the problem.
Thanks for your help.
+1 to this too, a local user that had similar problems did the same. He uninstalled google play music update and corrected the problem. Also FWIW the Handcent SMS app was a suitable solution as well. Thanks for all the help on this forum.
  #2302 (permalink)
Old 03-03-2014, 10:34 PM
I have Two Tone detect setup and working, the only question is that is waits 1:20 seconds of audio before it emails it out and the page is normally done by the :20 second mark but I have it set to :30 just to be sure, any Ideas? Thanks in advance!
  #2303 (permalink)
Old 03-04-2014, 9:38 AM
You probably need to adjust your Audio Squelch Threshold using the slider on the main screen. When there is no radio traffic, you should see "No Audio" on the main screen. When there is radio traffic, you should see frequencies being displayed. If there are frequencies being displayed all the time, move the slider to the right until you see "No Audio" during silence.
Andy
If you need help with TwoToneDetect please read this post first
  #2304 (permalink)
Old 03-04-2014, 9:34 PM
I thought I seen a discussion in the past in reference to Straight Talk phones. I have tried two gateway emails and I have had no luck. Is it possible or not to use TTD on Straight Talk text?
Thanks,
John
  #2305 (permalink)
Old 03-04-2014, 9:38 PM
ffryan76's Avatar
From 176002: Straight Talk gateway for straight talk using Verizon towers is xxxxxxxxxxx@mypixmessages.com
For Straight Talk that uses At&t towers is xxxxxxxxxxx@mms.att.net
  #2306 (permalink)
Old 03-04-2014, 10:02 PM
Thank you!
  #2307 (permalink)
Old 03-11-2014, 7:46 PM
Question on the Audio Output Device. I have this set to 1 in the config and when anything is received on the channel it plays in the speakers. I thought it would only play when the correct tones are detected? I have tried this on 3 windows XP boxes and all do the same. I am running V58 right now.
  #2308 (permalink)
Old 03-11-2014, 9:30 PM
You probably have that input playing through the speakers in the Windows sound mixer. You need to mute it through Windows, and then the program will play only when a page is received. As it is now you may hear an echo in the audio after a page is received as both Windows and the program play it, but the program will have a slight delay.
Andy
  #2309 (permalink)
Old 03-12-2014, 10:48 AM
Thumbs up
Andy
One of the problems with the detection of the tones is the sound cards in our computers do not receive the sound that well so we have to adjust it until we find the correct one that will work, like my tone setting should have been 2465 but for it to work on the on this system I had to change it to 2462 hz then it would work. It is not the computer software it is the sound cards we are using in our computer.
  #2310 (permalink)
Old 03-15-2014, 9:01 PM
Remote tones = 60
What happens if the hosting website is down for several hours? Is there a cached copy or does is 60+ minutes everything null and void?
  #2311 (permalink)
Old 03-16-2014, 6:18 AM
Originally Posted by snig64 View Post
Remote tones = 60
If the program is not able to retrieve the remotely hosted file for any reason, it will revert to using the local tones.cfg file that is in the same directory as the program. If it is able to retrieve the remotely hosted file, it will overwrite the local tones.cfg file with the information that was retrieved remotely and this new information will then be stored locally.
  #2312 (permalink)
Old 03-18-2014, 10:25 AM
Default Options Request
Andy,
Thank you for adding the version of the program at the top of the program tab,
Can you also add a title label in the config menu to add a Name to that tab,
Example now it has Two ToneDetect v65
Config menu Title : Fire Paging or EMS Paging or County Paging
then it would show right after Two ToneDetect v65 Fire Paging
When I run multiple sound cards in a machine for each feed it would be nice to tell which program
goes with each feed, instead of just knowing the sound card input.
Also in the Editor Program , can you enable mouse Right click copy and paste.
right now you have to use keyboard short cuts <CTRL> C or V
thanks
Chris
  #2313 (permalink)
Old 03-18-2014, 1:06 PM
wizard of odd
Originally Posted by k7nbc View Post
Andy,
thanks
Chris
I agree. This would be very helpful.
  #2314 (permalink)
Old 03-18-2014, 3:18 PM
Originally Posted by silfam1 View Post
You can add that info in the field that is sent to your phone. We added phone numbers for the responder software that Andy developed. So when the message comes it includes the phone numbers our FF's dial to let dispatch know they are responding. It's pretty slick. And from a smartphone they can dial right from the text screen. If you add the URL for your online scanner they will be able to click on the highlighted link. It comes thru like this:
PFD Disp 860-xxx-xxxx Station_ 860-xxx-xxxx Scene Page Received at 18:00:29 on 01/07/14
I was wondering what the responder software was that lets dispatch know whos responding? Thanks
  #2315 (permalink)
Old 03-18-2014, 3:23 PM
FireTTD's Avatar
Our control panel will allow users to be prompted if they are responding to a call or not. And then when a member responds that they are attending the call, that prompt is recorded, and delivered back to our system, where it can then be delivered further to someone (aka dispatch, chief, etc) either via SMS or email.
We are expecting to launch our beta system later this week.
Best,
FireTTD
  #2316 (permalink)
Old 03-18-2014, 3:25 PM
OK Thanks
  #2317 (permalink)
Old 03-19-2014, 12:28 PM
I think silfam was referring to this:
https://sites.google.com/site/radioe...e/callinsystem
This is a way to set up your own call-in system for free, but it requires some technical know-how.
What Mike is referring to is a commercial service that he's starting soon that includes a number of features, including a call in system. There are several commercial call-in systems on the market today.
Andy
  #2318 (permalink)
Old 04-01-2014, 12:50 PM
Default External commands
Andy,
Is there any chance of getting a few variables added to the external command options? Mainly recording file name, description field and the name of the temporary wave file? I'm currently using 65c on the raspberry pi
Thanks for the great software!
  #2319 (permalink)
Old 04-01-2014, 9:19 PM
Originally Posted by ejd91717 View Post
Andy,
Those are all available:
Enter [d] to insert the current Tone Description, enter [mp3] to insert the mp3 filename, [amr] to insert the AMR filename, [wav] to insert the WAV filename (all paths relative to program directory)
Andy
  #2320 (permalink)
Old 04-14-2014, 7:40 PM
Hi all,
I am trying to get fivetonedetect to work. I have the file downloaded and extracted to the desktop, ffmpeg.exe is in the main folder for it. When I start the application the window comes up and then it closes. When I run the debug one it opens and runs some code and then that window closes. Any ideas on what could be happening?
Any help is appreciated
Thanks!
Tags
twotonedetect
