  #281 (permalink)
Old 11-29-2011, 2:00 PM
A Tone Found!
Checking for B Tone
Checking for B Tone
537.0
Checking for B Tone
537.0
2
Checking for B Tone
537.0
3
Checking for B Tone
537.0
4
Tone Set Found! 14:49:56
Logan Twp 14:49:56
My email address
My SMS number
delay timer 14:49:59
'c:\test.bat' is not recognized as an internal or external command,
operable program or batch file.
waiting for audio 14:50:04
recording audio 14:50:04
done writing WAV 14:50:32
Unhandled exception in thread started by <function alert at 0x02FEAAF0>
File "<string>", line 403, in alert
File "D:\Python\build\pyi.win32\TwoToneDetect52_debug\o utPYZ1.pyz/subprocess",
line 679, in __init__
line 893, in _execute_child
WindowsError: [Error 2] The system cannot find the file specified
  #282 (permalink)
Old 11-29-2011, 4:18 PM
gfdfortynine's Avatar
I'm by far an expert on this software but try deleting
alert_command = c:\test.bat
post_email_command = c:\test2.bat
from your tones.cfg
Also delete any of the unused [Tone#] stuff as well from this file as well
I had similar errors to yours and they were gone when I did the above
  #283 (permalink)
Old 11-29-2011, 4:22 PM
I'm by far no expert on this software but try deleting
from your tones.cfg
Hopefully you will get this reply in a timely manner seems I'm still being moderated because I'm new.
  #284 (permalink)
Old 11-29-2011, 4:36 PM
It's giving you that error because it can't find the file ffmpeg.exe
Please confirm that ffmpeg.exe exists in the same directory as TwoToneDetect52.exe
Andy
  #285 (permalink)
Old 11-29-2011, 7:19 PM
chad3405's Avatar
Just wondering if anyone has a way to start recording once a valid tone is detected.
I am not talking about with twotone, I looking for something that will record all radio traffic for the call so it can be reviewed later in training or call reviews. This would not need to be sent or anything just started and could be ended manually .
example:
A command to start audacity recording and keep it recording for the duration for the incident.
  #286 (permalink)
Old 11-29-2011, 8:35 PM
After placing the ffmpeg.exe file, it got to where it went to send the email. Now it's telling me my username and password are invalid. I used the base64 encoder for my password and I tried my username as just the name and as name@gmail.com. Nothing worked. Is there something else I am missing? Thanks for the help!
  #287 (permalink)
Old 11-29-2011, 8:57 PM
If you're using the program's config editor menu, you don't need to encode your password, just enter it normally. You only need to mess with encoding if you're manually editing the config.cfg file in a text editor, which you shouldn't need to do.
  #288 (permalink)
Old 11-29-2011, 9:07 PM
Im not able to use the config editor because there is no "save button" on it. It just has the fields on it and when I X out of it, it does not save the information. I even made the program window bigger to make the "save button" was not hidden and it's not there.
  #289 (permalink)
Old 11-29-2011, 9:08 PM
example:
I use Scanner Recorder Pro to record all traffic on the channel in parallel with TwoToneDetect. Since it allows VOX recording, the files aren't huge. This records all traffic all the time, regardless of whether a tone set has been detected. It also timestamps each recording segment. There is a free version that has less features that a lot of people also use.
If you really want to just record after a tone set is detected, Windows Sound Recorder may work for you, as I believe it can be run from the command line.
Andy
  #290 (permalink)
Old 11-29-2011, 9:10 PM
There should be a "Save & Exit" button at the bottom. Can you post a screenshot of what your config editor looks like?
  #291 (permalink)
Old 11-29-2011, 9:32 PM
I have the same problem with mine i can't use configuration screen and there is no save and exit button.
I posted the debug screen a couple days ago here if that will helps
http://forums.radioreference.com/str...ml#post1649531
  #292 (permalink)
Old 11-30-2011, 8:11 PM
I got things working Andy. I LOVE IT! Thanks so much! I do have one minor question... i want a wav file to play after a certain company is heard. "alert_command = c:\test.bat" What would I put as the command? Thanks!
  #293 (permalink)
Old 12-01-2011, 12:23 PM
Figured it out!
  #294 (permalink)
Old 12-01-2011, 12:54 PM
I am still having the same problem of false paging and certain districts not receiving their tones on their phones when that tone is set off. I don't know if this will help anyone but when our county tones districts out, the repeater does not unkey between the two tone sets. I have tried adjusting my Btonelength anywhere from .6 to 1.5. When it is at .6 or .8, all the districts that were paged out get their alerts but it will sometimes identify the Btone as an Atone and the Atone from the second page set as the Btone. When it is set in the 1.# range, it will not identify the correct district that is being paged second. Does anyone have any suggestions on this or is there a way that it could be made to do the standard Atone=1 sec and Btone=3 sec?
  #295 (permalink)
Old 12-03-2011, 11:54 AM
The ignore function is not working. With multiple co pages, once it gets the two tones (1st station), it is taking the end of the first tone and beginning of the next tone and false identifying a 2nd station page.
  #296 (permalink)
Old 12-03-2011, 2:28 PM
That's what I was thinking the problem was but wasn't sure. Any tips on how to fix the false paging and just pick up the districts that the page is meant for?
Justin
  #297 (permalink)
Old 12-03-2011, 4:29 PM
I have the same problem and haven't found a complete work around yet. Increasing the "B" tone length did help on some pages.
Tim
  #298 (permalink)
Old 12-03-2011, 5:26 PM
Tim
Tim,
I tried that as well and had the result of two departments being paged to a call and only one of the departments that was paged received the page on their phones. The other tone was misinterpreted as another tone in the county due to the fact that 8 out of 10 tones in our county are reversed between the A and the B tones. Right now I have the Btonelength set at .995 and it actually happened again this morning on a medical call. One district that was paged received the correct page, the other page that was sent out was for a district on the other end of the county. Hopefully there will be a fix soon for this.
Justin
  #299 (permalink)
Old 12-04-2011, 5:12 PM
Default Add date to email message
Can you tell me how to customize the "page received at" "time" fields so the date will be shown? I was going to use the standard php strftime parameters to add it but I wanted to confer with you first. Thanks in advance.
  #300 (permalink)
Old 12-04-2011, 5:35 PM
i need help i am trying to set the twotone detector 52 vers. up on a mac. can anyone help me?
Tags
twotonedetect
