  #3601 (permalink)
Old 12-03-2017, 8:47 AM
Any other options to upload calls to twitter since now audio boom wants to charge 10 dollars a month which is way to step
  #3602 (permalink)
Old 12-03-2017, 9:20 AM
Originally Posted by DC31 View Post
I donít have any idea if it would work, but have you considered loading the TTD audio file up to an ftp server and then writing a little python script that posts the link to the server file to your FB page or wall? Something similar to the way push notifications work through TTD.
Here is some info that I found:
Python Facebook tutorial - post to Facebook page in 4 steps - nikhil's blog
The steps outlined are badly out of date. Don't waste your time on them
  #3603 (permalink)
Old 12-03-2017, 9:46 AM
ffryan76's Avatar
I noticed that while reading. That why I asked about Twitter.
Another question about ftp servers. Do you need static IP address for it?
Sent from my SM-G920V using Tapatalk
  #3604 (permalink)
Old 12-03-2017, 11:26 AM
I donít think you need static ip.
  #3605 (permalink)
Old 12-07-2017, 1:48 AM
I too am looking for a new way to upload to Twitter and a place host audio files now that AudioBoo is charging per month. Anyone know of such another place?
  #3606 (permalink)
Old 12-07-2017, 10:56 AM
I too used to use AudioBoo. Yesterday, I found IFTTT and was able to get it setup to post to Twitter.
https://ifttt.com/discover
I found it easy to setup, as it works on if/then statements. If it receives an email, then it posts to Twitter. It gives you the email address to sent to and you link your Twitter to it. Whenever it receives an email, it can post the subject, body, attachment, etc. to Twitter. I also have my Twitter linked to Facebook, so if something is posted to Twitter, it also posts to Facebook. I just put that email address into the same place where I used the audioboo email address.
If anyone wants to see how mine displays, Twitter is @FayetteBremer. Facebook is fb.me/fayettebremerbuchananfirepages
  #3607 (permalink)
Old 12-07-2017, 11:01 AM
ffryan76's Avatar
I've tried that for Facebook pages and get Gmail services error and it fails to trigger the event. There is no explanation on the error.
  #3608 (permalink)
Old 12-07-2017, 11:12 AM
I have Gmail accounts that are used to send the emails in Two Tone. The Gmail accounts are setup with 2 step verification with an app specific password for Two Tone.
IFTTT was then setup to use the email command to post to Twitter. The Twitter account is setup to post to a Facebook Page.
  #3609 (permalink)
Old 12-09-2017, 8:53 PM
lookatfreqs's Avatar
Using latest Windows 10 with latest ffmpeg.exe, AMR emails are not sending, getting this error when running debug:
Automatic encoder selection failed for output stream #0:0. Default encoder for format amr (codec amr_nb) is probably disabled. Please choose an encoder manually.
Error selecting an encoder for stream 0:0
  #3610 (permalink)
Old 12-10-2017, 11:10 AM
Which applet did you use? I've been searching for 15 minutes.
  #3611 (permalink)
Old 12-10-2017, 11:13 AM
Created my own. Select new applet, select email for the if part. Select twitter for the then part.
Sent from my SM-G930R4 using Tapatalk
  #3612 (permalink)
Old 12-10-2017, 1:15 PM
There is a remote monitoring script posted here: http://www.twotonedetect.net/test/wp...7/ttdmon-1.txt
I fixed a problem with the FTP not working and changed some other things to more suit my needs. Here ya go:
line #s from the original file:
line 18: Ping %pingAddress% -n 1 -w 2500
line 47: start "" "%appName%" /HIGH /d TTD
line 62: shutdown /r /t 10 /c "Two Tone Detect is not running. The script is rebooting the computer."
line 70: c:\PROGRA~1\winscp\winscp.com /command ^
"open ftp://%ftpUser%:%ftpPassword%@%ftpServer%/" ^
"cd %sourceFolder%"
*Notables that some are common sense (that isn't so common):
1] the batch file must be in the same directory as the TTD program
2] the audio file must be in the same directory as the batch file
3] winscp must be installed
4] you must create a file on FTP server named TTDmonlog.txt (case sensitive) or you will get an error
*I have attached
A] an export of my task schedule (ttdcheck-tasksched). The batch file downloaded from Andy's website must be named check.cmd and in the c:\TTD69 directory (which is where my install is). (Win Vista+)
B] a copy of my batch file based on the original from http://www.twotonedetect.net/test/wp...7/ttdmon-1.txt
C] a copy of my batch file that cleans files over 7 days old from folders (clean7days.txt)
D] a copy of the 7 days task scheduler export (clean7days-tasksched.txt) (Win Vista+)
E] one second of silence in MP3 format
  #3613 (permalink)
Old 12-10-2017, 6:40 PM
Default Issue sending to T-Mobile phone
I have had problems sending to T-Mobile text message if included in a distribution list. I fixed by sending to the T-Mobile number only, similar what is done for Verizon now.
Has anyone else seen this issue ? If so, is it possible to get an option for T-Mobile numbers like for Verizon to do individual sends ?
  #3614 (permalink)
Old 12-10-2017, 8:08 PM
MikeOxlong's Avatar
Default New TwoToneDetect in the works - Python based
Thanks! I had signed up earlier but hasn't put much effort into getting it figured out yet.
Glad to hear it's still doable.
NVM, saw you rolled your own.
Mike.
  #3615 (permalink)
Old 12-11-2017, 11:11 AM
MikeOxlong's Avatar
Twitter and Facebook both dislike my audio attachment for some reason.
What format are you using for audio? I'm using wav format.
Mike.
  #3616 (permalink)
Old 12-11-2017, 4:07 PM
I use mp3 format for my Twitter and Facebook files
  #3617 (permalink)
Old 12-11-2017, 4:12 PM
MikeOxlong's Avatar
I checked your Facebook page and saw you were using mp3 so I dumped ffmpeg into the directory and we'll see what happens.
Mike.
  #3618 (permalink)
Old 12-11-2017, 5:11 PM
Is it possible to put in CC or better yet BCC email addresses. Since audioboom stopped allowing emails I've moved to IFTTT but I would like to protect the email address it goes to.
  #3619 (permalink)
Old 12-12-2017, 10:14 AM
Default TTD 69 not creating AMR files windows 10
I am having the same issue. Were you able to figure this out. The MP3's are being created and sending to emails fine, but the system isn't creating the AMR files. No text messages are going out. System give error message that it cannot fine the .amr file to send. I am on windows 10 64bit and ffmpeg is in the directory. I am using the 32bit ffmpeg as shown in some other windows...
Tags
twotonedetect
