| Streaming / Broadcasting / Audio Recording Interested in putting your scanner online for others to hear? Want to listen to other radios on the internet. This forum is here for you to discuss these topics related to streaming scanners online. |
04-06-2012, 3:01 PM
Originally Posted by jessebelanger
Thanks for the tip. Unfortunately, it didn't work. Program still sits at an empty prompt and does nothing, although two instances still appear in task manager.
Stumped.
Try downloading an older version and see if that produces the same problem. Make sure you restart after you install the older version before you try to run it.
04-08-2012, 2:28 PM
TwoToneDetect problems
i got it installed and it loads and even detects the tone but this is the error that it shows on the dos screen, this is on a xp machine
Long Tone Found! 15:15:46
delay timer 15:15:46
473.0 Atone1
473.0Atone2
A Tone Found! 15:15:46
Checking for B Tone 15:15:46
Checking for Long Tone 15:15:50
waiting for audio 15:15:52
recording audio 15:15:52
Unhandled exception in thread started by <function alert at 0x015D63B0>
File "<string>", line 427, in alert
File "D:\Python\build\pyi.win32\TwoToneDetect54c_debug\ outPYZ1.pyz/wave", line
500, in open
303, in __init__
IOError: [Errno 22] invalid mode ('wb') or filename: './audio/Test_Tone\t2_2012-
04-0815_16_06_583000.wav'
Exception AttributeError: "Wave_write instance has no attribute '_file'" in <bou
nd method Wave_write.__del__ of <wave.Wave_write instance at 0x01678198>> ignore
04-08-2012, 5:01 PM
473.0 Atone1
473.0Atone2
500, in open
303, in __init__
Are you using any special characters in the tone description? If so, try removing them and see if that clears the problem up for you.
Andy
04-08-2012, 6:20 PM
next step
thank you andy for the quick reply, what i did was delete the space and took the numbers out of the tone description and it seems to work however there was alot of errors on the debugger i wanted to pass along to you, below is the info on the screen, also im having problems getting it to send to the firefighters with at&t service some dont get it at all and the ones that do get it , it says the *.wav file was removed from the message, everyone else works fine any suggestions its there phone # @mms.att.net look below is that normal
recording audio 19:10:32
Checking for Long Tone 19:10:34
[-999, -999, 7.0]
7.0
done sleeping at 19:10:37
317.0
473.0 Atone1
311.0Atone2
done writing WAV 19:10:46
ffmpeg version N-39494-g41a097a Copyright (c) 2000-2012 the FFmpeg developers
built on Apr 3 2012 20:20:04 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 44.100 / 51. 44.100
libavcodec 54. 12.100 / 54. 12.100
libavformat 54. 3.100 / 54. 3.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 66.101 / 2. 66.101
libswscale 2. 1.100 / 2. 1.100
libswresample 0. 10.100 / 0. 10.100
libpostproc 52. 0.100 / 52. 0.100
[wav @ 0219AAC0] max_analyze_duration 5000000 reached at 5015510
Input #0, wav, from './audio/Testt_2012-04-0819_10_46_088000.wav':
Duration: 00:00:13.93, bitrate: 352 kb/s
Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 11025 Hz, 2 channels,
s16, 352 kb/s
Please use -b:a or -b:v, -b is ambiguous
[mp3 @ 022BE920] Unsupported sample rate.
Output #0, mp3, to './audio/Testt_2012-04-0819_10_46_088000.mp3':
Metadata:
TSSE : Lavf54.3.100
Stream #0:0: Audio: mp3, 11025 Hz, 2 channels, s16
Stream mapping:
Stream #0:0 -> #0:0 (pcm_s16le -> libmp3lame)
Press [q] to stop, [?] for help
size= 55kB time=00:00:13.93 bitrate= 32.3kbits/s
video:0kB audio:55kB global headers:0kB muxing overhead 0.060482%
done converting to MP3 19:10:46
mp3 email sent! 19:10:48
04-08-2012, 7:44 PM
[-999, -999, 7.0]
7.0
317.0
473.0 Atone1
311.0Atone2
s16, 352 kb/s
Metadata:
TSSE : Lavf54.3.100
Stream mapping:
Yeah that's all normal, working fine. You may try sending to those phones as an AMR instead of mp3 (use the amr_emails field), or reducing the bit rate of the mp3 encoder to make the mp3 files smaller (in the edit config window).
Andy
04-09-2012, 6:40 AM
Tool I used in tasting
Hi everyone, I just wanted to put this out if anyone needs it. When I was setting up TTD on my laptop at first I had just my email and phone number to test it. After setting it all up I used an APP for my Droid X phone called Ted Tones Out it's in the market. It's a Two tone (Motorola Minitor®) sequential pager tone generator. Allows user to input tone frequencies, tone durations and an optional voice dispatch message.
When testing I was using the microphone on mu laptop to pick up the tones. this way I didn't have to wait on a dispatch to see if I had set it up right. With Ted Tones Out I can also use it to send out special announcements to members like training tonight at 1900 or work bee today at 0800, Thanks everyone for your input.
Eddie Murphy
KC2PPE
kc2ppe@stny.rr.com
May you always be Blessed and be a Blessing to others
"911 - a number we'll always remember"
"9-11-2001 - a date we'll never forget"
04-12-2012, 6:18 PM
not sending email
Hi All,
Thanks for a great product. I have set it up and received this message: Fire Department 1 page recieved at 18:00:23. I am assuming that the software is working but did not receive an email with the audio file. I believe I have the email info correct. outbound.att.net port 465. any ideas?
Joe
04-12-2012, 6:23 PM
this is what i got in the debog:
1796.0 Atone1
1796.0Atone2
A Tone Found! 19:20:05
Checking for B Tone 19:20:05
Checking for B Tone2 19:20:09
Tone Set Found! 19:20:09
Fire Department 1 19:20:09
silfam1@sbcglobal.net,8608823072@vte...072@vzwpix.com
8608823072@VTEXT.com
delay timer 19:20:09
'c:\test.bat' is not recognized as an internal or external command,
operable program or batch file.
731.0 Atone1
1591.0Atone2
waiting for audio 19:20:15
recording audio 19:20:15
731.0 Atone1
419.0Atone2
742.0 Atone1
1462.0Atone2
done writing WAV 19:20:43
ffmpeg.exe not found, sending as WAV file instead of mp3
Unhandled exception in thread started by <function alert at 0x015FE4F0>
File "<string>", line 469, in alert
File "<string>", line 301, in mail
File "D:\Python\build\pyi.win32\TwoToneDetect54c_debug\ outPYZ1.pyz/smtplib", l
ine 242, in __init__
ine 303, in connect
ine 352, in getreply
smtplib.SMTPServerDisconnected: Connection unexpectedly closed
04-13-2012, 4:41 PM
Actually disregard all responses. The program is working great. Thanks for a great program!
04-14-2012, 10:15 AM
can anyone help me to get the program to work. i have team viewer so you can log in an remotely help.
thanks,
matt
04-14-2012, 10:57 PM
Bcc
Hi all,
I am looking to find where to click the BCC checkbox. I looked in the config mgr but don't see it. Could someone shoot me a screen shot of where it might be please. Thanks for your help.
04-15-2012, 9:05 AM
Originally Posted by silfam1
Hi all,
What version are you using? The BCC was just added in version 55. For some reason, SourceForge was listing version 54c as the latest version, so I've fixed that. The BCC option should be right between the MP3 Encoding Bitrate and the Save & Exit button.
Andy
04-15-2012, 10:35 AM
Hi Andy
Thanks for the quick response. I am not sure what version it is because I looked for that too and couldn't find it. Could you tell me where Please where that info is located? And if I do have the older version I will certainly download the newest. Thanks again.
Joe
04-15-2012, 12:35 PM
Joe
It's in the filename for the .exe file. TwoToneDetect54c.exe is version 54c, TwoToneDetect55.exe is version 55, etc.
Andy
04-15-2012, 2:27 PM
Ok thanks again.
04-15-2012, 7:45 PM
can anyone help me i can get the program downloaded but i cant seem to get the ffmpeg.exe into the file right. please let me know if you can help. mattnelson26@aol.com put subject two tone detect
thanks,
matt
04-16-2012, 8:06 AM
thank you and quick question
thank you aaknitt for this great program, i have been running it non stop for months without a problem.
quick question : i am starting to add alot of tones and numbers , is there a way to incorporate possibly a spreadsheet instead of notepad ? ( putting cell numbers into columns ) as i add numbers i have to scroll way over to get to the end of the list.
thank you again
pete
04-16-2012, 8:11 AM
Hi Pete
I started a file in Notepad and after I add an email or text number. I just copy and paste. I hope this helps.
04-17-2012, 2:19 PM
IO Err Invalid number of channels
Andy,
Excuse me if this one has been answered previously, I can't find it. I am trying to set up V55 on a vista computer. the tone detection algorithm seems to be working fine but no emails being sent. It seems to indicate an invalid number of channels. Any suggestions?
Jim
04-17-2012, 4:40 PM
Originally Posted by DC31
Andy,
Jim
I seem to remember something similar in a previous post, although I can't find it at the moment. If I recall correctly, restarting the program or the computer (can't remember which) seemed to fix it.
Andy
