  #681 (permalink)
Old 07-03-2012, 7:21 PM
silfam1's Avatar
Default I heartily second that!
Originally Posted by ifaieta View Post
Andy,
Just a big thank you for the creation and support you have given with this software. I think I speak for most of us here by saying you have improved FD and emergency service response times and assisted department comunications in ways that they might have said thanks for. Thanks to your software my department can cut back on purchasing new pagers do to "narrowbanding" and utilize what you have produced. Again "Thank you " and keep up the good work.
  #682 (permalink)
Old 07-04-2012, 2:11 PM
NO, NO, NO, NO!
This software is NOT A REPLACEMENT FOR PAGERS. Using it as such is playing with fire. It is NOT mission-critical grade software, and any system that relies on commercial wireless (cell phone and text messaging) for messaging runs the risk of delayed or dropped messages.
Buy the pagers. This software is for SECONDARY alerting and hobbyist use only.
Andy
  #683 (permalink)
Old 07-06-2012, 6:50 PM
wizard of odd
Anyone else have a hard time getting it play audio while recording? I've tried every output with no luck. Any ideas?
  #684 (permalink)
Old 07-07-2012, 8:38 PM
wizard of odd
Are those lines in color of any concern? It's recording and emailing fine, it just won't play what its recording. I've watched the sound mixer graphs and it looks like its not playing.
  #685 (permalink)
Old 07-08-2012, 12:23 AM
I have not played with this. I will try to take a look next time I am at the console.
I believe that by default the Mic in (and sometimes audio in) do not play back to the audio output as it would cause horrible echoing. You should be able to change this in the audio props for windows. This allows me to here whatever is being fed to the box, but is not only during recording. (I know of a commercially available product simply mutes\unmutes the speakers to play back during recording). This method for me only allows play back over the same audio device, as I have multiple cards.
  #686 (permalink)
Old 07-10-2012, 4:20 PM
I was not able to get the "playback during record" option to do anything for me. No matter how it was set, the system audio config (main and input volume playback levels) controlled the audio.
  #687 (permalink)
Old 07-10-2012, 10:53 PM
wizard of odd
Can't get the program to run a .bat file after recording either. .bat files run fine upon detection though.
  #688 (permalink)
Old 07-11-2012, 8:14 AM
The colored lines aren't a problem, but the unhandled exception is. I'm not sure what's causing that, I've never seen it before. That might explain both of the problems you're having, but I don't have any ideas on how to fix it.
Andy
  #689 (permalink)
Old 07-11-2012, 8:47 AM
Send a message via AIM to cobraultra
ffexpCP - where is the .bat file for the after recording? I had to place it on the root of the C:\ Drive before it would work. EXP: c:\firecall.bat
  #690 (permalink)
Old 07-11-2012, 8:51 AM
I also have a question / request depending on what the answer is...
So I am using a .bat file to run after the recording that runs a SQL command that pushes a bunch of data into a SQL database. Then the SQL database send the email out. The program does not seem to work if you do not put in an email address or a functioning email account in the main config file. Is there a way around this? Can it be an option in the future to not provide email info if there isnt a work around?
  #691 (permalink)
Old 07-11-2012, 9:08 AM
I was wondering if there was a way to add name tags to each email and phone number address. That way I don't have to keep a separate list next to the computer.
Great program!!!
  #692 (permalink)
Old 07-11-2012, 2:24 PM
wizard of odd
I didn't see the 'unhandled exception' before you pointed it out. I guess I was distracted/paranoid about the bright colors showing up.
Anyway, I figured out how to copy and paste from the debug, I hope it helps more than the limited screenshot.
924.0 Atone1
924.0Atone2
A Tone Found! 15:07:42
Checking for B Tone 15:07:42
Checking for B Tone2 15:07:45
Tone Set Found! 15:07:45
xxxxxxxxxxStation 2 - City xxxxxxx 15:07:45
xxxxxxxxxxx@yahoo.com
;Email addresses to send AMR attachment to. Separate iwth commas
delay timer 15:07:45
C:\TwoToneDetect>start z:/playwav10/playwav.exe C:/TwoToneDetect/yahoo.wav
waiting for audio 15:07:45
634.0 Atone1
recording audio 15:07:45
634.0Atone2
A Tone Found! 15:07:45
Checking for B Tone 15:07:45
Checking for Long Tone 15:07:49
done writing WAV 15:08:13
ffmpeg version N-32726-ga254452, Copyright (c) 2000-2011 the FFmpeg developers
built on Sep 19 2011 19:49:13 with gcc 4.6.1
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --ena
ble-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-
libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --ena
ble-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --en
able-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 16. 1 / 51. 16. 1
libavcodec 53. 16. 0 / 53. 16. 0
libavformat 53. 12. 0 / 53. 12. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 43. 2 / 2. 43. 2
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
[wav @ 01E084E0] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 01E084E0] max_analyze_duration 5000000 reached at 5015510
Input #0, wav, from './audio/xxxxxxxh_2012-07-1115_08_1
3_326000.wav':
Duration: 00:00:27.86, bitrate: 352 kb/s
Stream #0.0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 11025 Hz, 2 channels,
s16, 352 kb/s
[mp3 @ 02A717C0] Unsupported sample rate.
Output #0, mp3, to './audio/xxxxxxxxh_2012-07-1115_08_13
_326000.mp3':
Metadata:
TSSE : Lavf53.12.0
Stream #0.0: Audio: mp3, 11025 Hz, 2 channels, s16, 32 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (pcm_s16le -> libmp3lame)
Press [q] to stop, [?] for help
size= 109kB time=00:00:28.00 bitrate= 32.0kbits/s
video:0kB audio:109kB global headers:0kB muxing overhead 0.029461%
done converting to MP3 15:08:14
mp3 email sent! 15:08:18
[wav @ 01BB8580] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 01BB8580] max_analyze_duration 5000000 reached at 5015510
Input #0, wav, from './audio/xxxxx_2012-07-1115_08_1
3_326000.wav':
s16, 352 kb/s
Output #0, amr, to './audio/xxxxxx_2012-07-1115_08_13
_326000.amr':
Metadata:
encoder : Lavf53.12.0
Stream #0.0: Audio: amr_nb, 8000 Hz, 1 channels, s16, 10 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (pcm_s16le -> libopencore_amrnb)
0.500000 0.500000
size= 37kB time=00:00:27.88 bitrate= 10.8kbits/s
video:0kB audio:37kB global headers:0kB muxing overhead 0.015941%
done converting to AMR 15:08:20
Unhandled exception in thread started by <function alert at 0x02600630>
File "<string>", line 485, in alert
File "<string>", line 311, in mail
File "D:\Python\build\pyi.win32\TwoToneDetect55a_debug\ outPYZ1.pyz/smtplib", l
ine 724, in sendmail
smtplib.SMTPRecipientsRefused: {';Email addresses to send AMR attachment to. Se
parate iwth commas': (555, '5.5.2 Syntax error. nh1sm14969695igc.11'), '': (555,
'5.5.2 Syntax error. nh1sm14969695igc.11')}
  #693 (permalink)
Old 07-11-2012, 5:22 PM
Looks to me like you've put a bad e-mail address into it somewhere.
  #694 (permalink)
Old 07-12-2012, 10:36 AM
Question Help with e-mail connection
Thanks for an excellent program. And my apologies if I should have started a new thread.
I'm trying to set up a secondary notification system for my County HAZMAT team to message phones when members are out of pager range.
I'm working with the older version at this time. I can detect pages, create the .wav file, but cannot send e-mail. I first tried using Outlook to link to our GMail account, but it would not work. Our account is setup accordingly for external access via STMP/POP3.
Yesterday I set up Thunderbird to access our GMail account and was successful. So I'm certain the STMP access is correct. I used the same parameters in TwoTone and still cannot send the page file.
Would appreciate if someone could get back to me with troubleshooting info. Since we rely on volunteers who work out of pager range, this program would solve a problem.
Burlington County currently has a Rip n Run program for the other stations, but since we are in County OEM, our CAD assignment cannot be set up to e-mail.
  #695 (permalink)
Old 07-12-2012, 12:33 PM
What is the output in the debug window when you receive a page? If you can paste that here it would be helpful.
Andy
  #696 (permalink)
Old 07-12-2012, 8:33 PM
wizard of odd
Well, I was afraid it wasn't working because of a sound card driver issue, so I took the extreme step of removing all but one sound card, reformatting and putting a fresh install of Windows7 on the computer.
Still cannot get playback during recording. Ugh.
It's running all .bat files now though.
  #697 (permalink)
Old 07-13-2012, 4:59 PM
Smile Cannot e-mail files
Here is the debug report.
A Tone Found! 17:18:45
Checking for B Tone 17:18:45
Checking for B Tone2 17:18:48
Tone Set Found! 17:18:48
Sta909 17:18:48
brian_petuch@merck.com
2672783711@messaging.nextel.com
delay timer 17:18:48
waiting for audio 17:18:49
recording audio 17:19:07
done writing WAV 17:19:34
[wav @ 01FC9AA0] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 01FC9AA0] max_analyze_duration 5000000 reached at 5015510
Input #0, wav, from './audio/Sta909_2012-07-1317_19_34_840000.wav':
s16, 352 kb/s
[mp3 @ 020ED460] Unsupported sample rate.
Output #0, mp3, to './audio/Sta909_2012-07-1317_19_34_840000.mp3':
Metadata:
TSSE : Lavf53.12.0
Stream mapping:
done converting to MP3 17:19:37
Unhandled exception in thread started by <function alert at 0x0156B570>
File "<string>", line 469, in alert
File "<string>", line 306, in mail
line 242, in __init__
line 303, in connect
line 352, in getreply
smtplib.SMTPServerDisconnected: Connection unexpectedly closed
  #698 (permalink)
Old 07-14-2012, 11:19 PM
Sta909 17:18:48
nvalid.
s16, 352 kb/s
Metadata:
TSSE : Lavf53.12.0
Stream mapping:
It's not liking something with the SMTP connection, but I'm not sure what. Gmail seems to work well for most people, so I'm not sure what the issue is. Are you behind a firewall that may restrict that traffic for some reason? If it's working with Thunerbird thought I would think it would work with this program too.
Andy
  #699 (permalink)
Old 07-16-2012, 10:01 PM
Default Will Two-Town Detect work with a PL Tone?
Hi, I am a journalist trying to keep up with the local FD to get some good action pictures.
This sounds awesome. But I think my FD uses a single PL tone, and not a two-tone dispatch.
Any advice?
  #700 (permalink)
Old 07-17-2012, 10:32 AM
Default MP3 Bitrate
Hello. First off great program.
Has anyone else experienced this? I change the bit rate for mp3 as I would like higher audio quality.
However it seems that no matter what bit rate is specified, it gets encoded at 32000. Upon investigation, I get the following warning in the debug window during the compression scheme:
Input #0, wav, from './audio/Whatever_2012-07-1704_32_21_203000.wav':
Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 11025 Hz, stereo, s16
, 352 kb/s
Please use -b:a or -b:v, -b is ambiguous
[graph 0 input from stream 0:0 @ 023197c0] tb:1/11025 samplefmt:s16 samplerate:1
1025 chlayout:0x3
Output #0, mp3, to './audio/Whatever_2012-07-1704_32_21_203000.mp3':
I copied ffmpeg to a separate directory along with a wav file. When I run the command:
ffmpeg -i Test.wav -b 32000 Test.mp3
I get the same error
If I pass it as:
fmpeg -i Test.wav -b:a 32000 Test.mp3
Everything seems to work with no warning and depending on the specified bitrate, the quality of the audio changes.
Maybe this is a newer version of ffmpeg than the software was designed for and the -b was changed to -b:a in an upgrade?
I looked at the Python code and it seems it just passes the -b
Suggestions?
Tags
twotonedetect
