  #1101 (permalink)
Old 01-03-2013, 8:32 PM
KLH KLH is offline
I believe I am having issues with 58 also.
Went from 56 to 58, and the program keeps jumping around on the tone frequency on dead silence. Also when I unplugged the cable from the scanner, the program immediately picks up 1 page every second it seems. I am running Windows XP and using a USB sound card if it matters.
I downgraded to 57, and everything works like normal. Only thing changed is the main exe file.
  #1102 (permalink)
Old 01-03-2013, 9:01 PM
ve3nsv's Avatar
Send a message via MSN to ve3nsv
I hope to give V58 a test this weekend Andy and will report my findings.
  #1103 (permalink)
Old 01-03-2013, 9:48 PM
Thanks, appreciate all of the testing from everyone.
At this point I'm not sure what the issue might be with v58, the changes from v57 to v58 should be really pretty minor with respect to the tone detection algorithm. I have it working on three different computers running three different OS's with three different sound cards. I also tried changing my Btonelength parameter to .6 but it was still picking up pages (although it got messed up with certain stacked tone combinations).
I'd recommend setting Btonelength to the actual length of the Btone or even .2 seconds longer. That seems to give the best results during stacked pages.
Keep the feedback coming.
Andy
  #1104 (permalink)
Old 01-04-2013, 11:52 AM
I am just not sure what is going on with v58 on my setup. I went back and started with clean configs from the v58 zip. I added a few tones to tones.cfg and only added my email setup to the config.cfg. I am still not catching tones on v58. There must be something that I am overlooking.
V56:
A Tone Found! 09:14:15
Checking for B Tone 09:14:15
Checking for B Tone2 09:14:16
Tone Set Found! 09:14:16
Medic3 09:14:16
email@email.com
delay timer 09:14:16
waiting for audio 09:14:16
recording audio 09:14:16
v58:
1357319655.35
2.8 09:14:16
1357319656.28
done sleeping at 09:14:18
1357319658.89
pre-record
1357319658.89
post-record
1357319659.06
Checking for B Tone2 09:14:19
1357319659.06
5007.0
Checking for Long Tone 09:14:19
The tone shown here is:
Atone = 768
Btone = 941
Btonelength = 3
  #1105 (permalink)
Old 01-04-2013, 4:16 PM
Adding to the discussion.... Yeah, 58 not working here. Backing up a little, been running 55c, rock solid even ruining XPe on a thin client. Rock solid. Started using 57 and experienced some issues both Vista and XPe. It will find the tones ok and then it throws an error "IndexError: list index out of range" right in the midst of listing my tones in the tone file. It happens randomly. This example happened during stacked tones. The first tone-out functioned properly but the second didn't. Any idea what it doesn't like on line 587? It finds the tone set ok but does not record. I moved confg and tone files directly over form 55c.
580.0 Atone1
1887.0Atone2
580.0 Atone1715.0Atone2
580.0 Atone1
1494.0Atone2
639.0 Atone1
1064.0Atone2
344.0 Atone1
344.0Atone2
A Tone Found! 13:04:24
Checking for B Tone 13:04:24
Checking for B Tone2 13:04:25
Tone Set Found! 13:04:25
UNION GAP FIRE Station 85 --- 13:04:25
admin@email.com
Succesfully retrieved local tone info
delay timer 13:04:25
waiting for audio 13:04:26
recording audio 13:04:26
344.0 Atone1
344.0Atone2
A Tone Found! 13:04:30
Checking for B Tone 13:04:30
Checking for Long Tone 13:04:34
Tone1
Tone2
Tone3
Tone4
Tone5
Tone6
Tone7
Tone8
Tone9
Tone10
Tone11
Tone12
Tone13
Tone14
473.0 Atone1
473.0Atone2
A Tone Found! 13:04:36
Checking for B Tone 13:04:36
Checking for Long Tone 13:04:40
645.0 Atone1
645.0Atone2
A Tone Found! 13:04:42
Checking for B Tone 13:04:42
Checking for B Tone2 13:04:43
Checking for B Tone2 13:04:44
Tone Set Found! 13:04:44
WEST VALLEY FIRE --- 13:04:44
admin@email.com
delay timer 13:04:44
344.0 Atone1
344.0Atone2
A Tone Found! 13:04:44
Checking for B Tone 13:04:44
waiting for audio 13:04:45
recording audio 13:04:45
Checking for Long Tone 13:04:48
473.0 Atone1
645.0Atone2
645.0 Atone1
645.0Atone2
A Tone Found! 13:04:49
Checking for B Tone 13:04:49
Checking for Long Tone 13:04:53
580.0 Atone1
1693.0Atone2
Tone1
Tone2
Tone3
Tone4
Tone5
File "<string>", line 587, in alert
Tone6
Tone7
Tone8
Tone9
Tone10
Tone11
Tone12
Tone13
Tone14
650.0 Atone1
1758.0Atone2
650.0 Atone1
done writing WAV 13:05:50
645.0 Atone1
2645.0Atone2
done converting to MP3 13:05:58
MP3 Email sent! 13:06:04
Doug
  #1106 (permalink)
Old 01-04-2013, 6:00 PM
having a bit of an issue with the program picking up 2 of the 3 stations pager tones
all 3 stations tones come off the same tower. my station i get no problems at all picks it up and it does its thing.
the other 2 stations however it is not picking them up. i tried changing the b tone length for those 2 stations from 3 down to 2 and the one station did a pager test today and it did not pick it up.
i am running V56 on my desktop for all the stations. I don't want to mess with it since it is working well for my station and we haven't rolled it out to the other stations yet until we get it working for their tones.
i did have and issue previously where i wasn't getting anything at all from any of the stations and that was traced back to the volume on the scanner not being high enough.
has anyone run into this and how did you resolve it.
  #1107 (permalink)
Old 01-04-2013, 9:10 PM
Can you copy the contents of your tones.cfg file into a forum post so thar we can see how you have that set up? It sounds like it should be a real simple fix.
  #1108 (permalink)
Old 01-04-2013, 9:53 PM
Default Issues...
Running on windows 7 pro 64-bit.
Every time I try to start the application I get the following errors:
File "<string>", line 123, in <module>
File "D:\Python\build\pyi.win32\TwoToneDetect58_debug\o utPYZ1.pyz/base64", line 76, in b64decode
TypeError: Incorrect padding
Longtone1
File "<string>", line 408, in <module>
NameError: global name 'control_scanner' is not defined
File "<string>", line 473, in <module>
NameError: name 'input_device' is not defined
Any ideas on what is causing this issue?
  #1109 (permalink)
Old 01-04-2013, 10:39 PM
Default Tones Sending
Is anyone having an issue with the program sending a recording for a tone when a tone has not gone off? I have set up multiple tones for my department, such as station tones, and recall/Duty squad/Box tones. For the past few days, the program has sent various recall/Duty squad tones to my Chief and Deputy in the middle of the night when in reality, it was just a recording of department activity. It seems to be recording department activity when there is no tone present, but thinks there is a tone. It mainly records random radio traffic for the Duty squad and Box tones, but does for station 1 tone - just not as frequent. I'm not sure how to fix it and was looking for some help if possible. Here are my tone settings below. Thanks again!
[Tone1]
Atone = 1217.8
Btone = 1901
Btonelength = 3
Btonedebounce = 0
Description = Duxbury Fire Station 1
mp3_Emails =
amr_Emails = 781*******@vzwpix.com
ignore_after = 60
radio_frequency = 460.575
[Tone2]
Atone = 1743
Btone = 1153.4
Btonelength = 3
Description = Duty Squad 1
Btonedebounce = 0
ignore_after = 60
mp3_emails = bost*********@gmail.com,alerts@all***********.com
amr_emails = 781*******@vzwpix.com,508*******@vzw...***@vzwpix.com
[Tone3]
Atone = 1743
Btone = 1185.2
Btonelength = 3
Description = Duty Squad 2
Btonedebounce = 0
ignore_after = 60
mp3_emails = bos*******@gmail.com,alerts@all**********.com
amr_emails = 508*******@vzwpix.com,781*******@vzw...***@vzwpix.com
[Tone4]
Atone = 1743
Btone = 1217.8
Btonelength = 3
Description = Duty Squad 3
Btonedebounce = 0
ignore_after = 60
mp3_emails = bos********@gmail.com,alerts@all***********.com
[Tone5]
Atone = 1743
Btone = 1251.4
Btonelength = 3
Description = Duty Squad 4
mp3_emails = bos*********@gmail.com,alerts@all************.com
Btonedebounce = 0
ignore_after = 60
[Tone6]
Atone = 1743
Btone = 1901
Btonelength = 3
Description = Box
Btonedebounce = 0
ignore_after = 60
mp3_emails = bos********@gmail.com,alerts@all************.com
[Tone7]
Atone = 1251.4
Btone = 1901
Btonelength = 3
Description = Chief_Deputy
Btonedebounce = 0
ignore_after = 60
mp3_emails = bos********@gmail.com,alerts@all****************.c om
[Tone8]
Atone = 1743
Btone = 1357.6
Btonelength = 3
Description = Tech Rescue
Btonedebounce = 0
ignore_after = 60
mp3_emails = alerts@all**************.com,bos***********@gmail. com
[Tone9]
Atone = 1743
Btone = 1285.5
Btonelength = 3
Description = Medic
Btonedebounce = 0
ignore_after = 60
mp3_emails = bos***********@gmail.com,alerts@all*...***** ***.com
  #1110 (permalink)
Old 01-05-2013, 4:13 AM
[Tone1]
Atone = 1217.8
Btone = 1901
Btonelength = 3
Btonedebounce = 0
mp3_Emails =
ignore_after = 60
[Tone2]
Atone = 1743
Btone = 1153.4
Btonelength = 3
Btonedebounce = 0
ignore_after = 60
[ail]
Set your Btonedebounce value to 2 or 3 and i would bet your chief will be a happier sleeper.
  #1111 (permalink)
Old 01-05-2013, 8:38 AM
Tone 1
Atone= 339.6
Btone= 321.7
Btonelength= 3
Btonebounce= 0
Description= station 1
mp3_emails= (edited out for this)\
ignore_after = 60
Tone 2
Atone= 368.5
Btone= 330.5
Btonelength= 2
Description= station 2
Tone 3
Atone= 389.0
Btone= 330.5
Btonelength= 2
Description= station 3
For stations 2 and 3 i put the Btonelength to 2 after i didnt get anything with it set to 3
My station is station 1 and everything comes through no problem whether it be a pager test or an actual call.
Also all 3 stations tones come off the same tower which is less than 1 km from my house
hope this gives the info needed to help troubleshoot this issue
thanks
  #1112 (permalink)
Old 01-05-2013, 9:38 AM
Tone 1
Atone= 339.6
Btone= 321.7
Btonelength= 3
Btonebounce= 0
ignore_after = 60
Tone 2
Atone= 368.5
Btone= 330.5
Btonelength= 2
Tone 3
Atone= 389.0
Btone= 330.5
Btonelength= 2
thanks
A couple things to try:
1. Where are the brackets around Tone 1 tone 2, etc.? The correct format is [Tone1] for each of these, no space between Tone and 1 either. Use this format for each tone set.
2. Use the same seven lines beneath the [ToneX] that you used in Tone 1. Set each of the Btonelength's to 2 and each Btonedebounce to 2.
Then give it a try.
  #1113 (permalink)
Old 01-05-2013, 9:45 AM
Then give it a try.
sorry bout that i just typed what was in my tone.cfg file. couldnt get the copy to paste into the window.
ok i will go back into the file and change thoes things around and will let you know how it works out. station 3 does a pager test later today
thanks
  #1114 (permalink)
Old 01-05-2013, 10:25 AM
Andy,
Great program! I have a few departments running on a modded version of TTD. It works great! Good work!
  #1115 (permalink)
Old 01-05-2013, 11:17 AM
Thank you for the help, I'm sure they will be happier too.
  #1116 (permalink)
Old 01-06-2013, 4:03 PM
I think everything is working fine now with v58. It turned out to be my setup (as expected), I had a very low tone tolerance set in my config.cfg. The default is 2%, but I had mine dialed down to 0.5%. There seems to be a slight difference in the decoding of tone frequencies between v56 and v58. v56 sees my B Tone as 1285, but v58 sees it as 1278, thus outside of my configured tone tolerance.
I bumped my tone tolerance to 1%, and everything has been looking good.
  #1117 (permalink)
Old 01-06-2013, 4:21 PM
Send a message via AIM to mattnelson26 Send a message via Skype™ to mattnelson26
Andy,
what happened to all the files on SourceForge?
  #1118 (permalink)
Old 01-06-2013, 6:12 PM
Longtone1
Something is messed up with your config.cfg file, probably the email password. Did you manually edit the config.cfg file or did you change the settings through the program's "Edit Config Info" menu?
Andy
  #1119 (permalink)
Old 01-06-2013, 6:13 PM
Originally Posted by mattnelson26 View Post
Andy,
I will eventually get previous versions posted on the program page. If you're looking for source files, shoot me an email and let me know what you need.
Andy
  #1120 (permalink)
Old 01-06-2013, 6:15 PM
I was getting that IndexError: list index out of range error with v57 occasionally also. I think I fixed it in v58...what's the issue you're having with v58?
Andy
Tags
twotonedetect
