  #1201 (permalink)
Old 01-22-2013, 9:51 PM
Forts's Avatar
Mentor
Send a message via ICQ to Forts
Sure, I can send you my file.. just let me which email address to use. I'm using my tones.cfg from v52 (I haven't updated in a while) so perhaps there is a formatting issue there? I fired up v58 today using the same settings that I was using for v52 (as far as tone tolerence, offset etc) and it didn't decode anything at all... it seemed the frequency displayed was off from the actual tone frequencies.. so I need to do a little tweaking there I believe.
  #1202 (permalink)
Old 01-23-2013, 7:17 AM
If you're using an early v58, it had a build problem that resulted in tone offsets. Use v58a and that problem should go away.
Andy
  #1203 (permalink)
Old 01-23-2013, 1:28 PM
Default No tones
Hello everyone, I am setting this program up for another department and having issues with the tones. For some reason the software is not detecting the A-B tone config. I have set up. The program is detecting the long tones without a issue but will not detect the A-B tones. The tone tolerance is set to 2.0 and the programming is below. Let me know what you guys think. Also is it ok to have the scanner volume turned down or should it be up all the way. Thanks again.
[Tone1]
Atone = 330.5
Btone = 810.2
Btonelength = 2
Btonedebounce = 0
Description = Tone 1
mp3_Emails = chief@fire.*****.ma.us
ignore_after = 60
radio_frequency = 453.1875
amr_emails = 781*******@pm.sprint.com,781*******@vzwpix.com
text_Emails = chief@fire.******.ma.us
[Tone2]
Atone = 330.5
Btone = 767.4
Btonelength = 2
Description = Tone 2
mp3_emails = chief@fire.*****.ma.us
Btonedebounce = 0
text_Emails = chief@fire.*****.ma.us
[Tone3]
Atone = 330.5
Btone = 726.8
Btonelength = 2
Description = Tone 3
Btonedebounce = 0
[Longtone1]
Longtone = 855.5
Longtonelength = 5
Description = EMT Tone
Longtonedebounce = 0
[Longtone2]
Longtone = 903.1
Longtonelength = 5
Description = All Call
  #1204 (permalink)
Old 01-23-2013, 2:10 PM
Do you have the volume turned down when you are having the issues with it picking up the tones? The volume needs to be loud enough that it will pick up the tones, but not too loud that it distorts. In my experience, about halfway seems to be about the best.
  #1205 (permalink)
Old 01-23-2013, 4:26 PM
Anyway to prevent falsing when normal voice traffic is on the channel, our B tone debounce setting is 3 but still get false pages.
  #1206 (permalink)
Old 01-23-2013, 4:33 PM
The volume was up about half way to full when I was testing, and as for the B tone debounce it was on 3 but i changed it and didn't make a difference and still didn't pick up the A-B tones.
  #1207 (permalink)
Old 01-23-2013, 8:26 PM
Try turning the volume up a little more. The low frequency tones (330.5) can be particularly difficult for TTD to detect. Also since tone tolerance is in % the range becomes narrower as the freq is lower. However with your 2% i would think you are ok. If you have access to a recording of the tone set as broadcast over the air, analyze it with Audacity to see what the tones really are.
  #1208 (permalink)
Old 01-23-2013, 10:00 PM
I have used a recording to analyze it and its the same numbers I put in TTD, plus or minus 1.0-2.0 points. Can the % tolerance go higher or what should be next?
  #1209 (permalink)
Old 01-23-2013, 10:17 PM
Are you trying to use scanner control via serial port? If so, don't, it's not working properly. Just leave the scanner parked on the frequency and don't use scanner control.
Andy
  #1210 (permalink)
Old 01-24-2013, 10:01 AM
Its not being used via serial port, just audio input. And the scanner is locked on that channel.
  #1211 (permalink)
Old 01-24-2013, 10:19 AM
When the two-tone pages are being sent, what is the "Status" on the main screen of the program? If it says "No Audio", you need to turn up the volume on your scanner or adjust the audio threshold down. Otherwise, check to see what frequency it's decoding and see if that matches your A/B tones.
Andy
  #1212 (permalink)
Old 01-25-2013, 10:15 PM
Default v58b Released
I just posted v58b on the program page, which is a bug fix and also includes an update to the TonesEditor program.
Version 58b Release Notes:
  • Fixed a bug preventing proper remote tone config file decryption
  • Added file open, save as, encryption, decryption to TonesEditor program
Andy
  #1213 (permalink)
Old 01-26-2013, 1:24 AM
chandler's Avatar
Send a message via Skype™ to chandler
My wont email me the audio but it does detect it why is it not emailing me? Can some one help? If so message me thanks
  #1214 (permalink)
Old 01-26-2013, 7:09 AM
Talking THANK YOU!
Originally Posted by oab2 View Post
What I do is use the normal email syntax in all my tones. Example: "bob fireman"<1234567890@email.com>,"jim smith"<12331231234@cell.com> (Note: this does not cause any problems for TTD.)
This way when I need to find someone in the tones I can either search by # or name. I send out a test/confirm message when a person desires to be added. I created my own tone set with audacity with a 440/500 AB toneset (these are far enough away from my tones to not cause problems). This includes a recorded message telling the recipient they have been added to the paging system but they must respond by text letting me know they got the message. Then I go into the email program (gmail) and find their response. The reason I have them respond by text is two fold. One I know it works for their phone (if not I try amr instead of mp3 in about 6 hours) and two, their phone number comes up as the sender in gmail, I search for that in my test tone list of contacts. when I find it I then remove it from the test list and add it to the appropriate fire tone list.
I hope that makes sense. My audacity tone file has all the different departments recorded confirmation messages in it. I just mute the ones I don't want to play on a given testtone.
You Have Just Made My wife very happy. I won't have to spend so much time at the computer trying to remember who I programmed! I sense more "at home" chores in my future
  #1215 (permalink)
Old 01-26-2013, 7:06 PM
krantzc93's Avatar
Default WILL NOT START!!!!!
Hello,
I used to use the 55a which suddenly stopped working one day (Would not start up when I clicked it, Would almost look like the task was self terminating). I havn't played with it in forever. So I checked back on the wesite to see if there was a later software out, which there was (58b). So i downloaded it on a different pc and did everything asked including pasteing the zipped FFMPEG.exe, into the root. This one seems to be doing the same thing, i didnt even touch the TONE file for i didnt want to mess anything up, and it to crashed. Anyone have any sugestions??? Im using windows 7 64 bit.
  #1216 (permalink)
Old 01-26-2013, 7:35 PM
krantzc93's Avatar
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\admin>C:\Users\admin\Desktop\TwoToneDetec t58b\TwoToneDetect58b_debug.ex
e
File "<string>", line 120, in <module>
File "C:\Users\Deer Creek Fire Dept\Documents\Python\build\pyi.win32\TwoToneDe
tect58b_debug\outPYZ1.pyz/iniparse.compat", line 217, in get
NoSectionError: No section: 'Section1'
File "<string>", line 225, in readtonefile
IOError: [Errno 2] No such file or directory: 'tones.cfg'
File "<string>", line 251, in <module>
NameError: global name 'tonesets' is not defined
C:\Users\admin>
  #1217 (permalink)
Old 01-26-2013, 10:08 PM
e
C:\Users\admin>
It looks like it's not seeing a tones.cfg file in the same directory as the program.
Andy
  #1218 (permalink)
Old 01-27-2013, 10:16 AM
Default 58b not emailing
Hello, thanks for the all the work you have done! I am having a problem with TTD not emailing. Here is a copy of the debug for 58b. Any help would be greatly appreciated. Thank you!
Succesfully retrieved local tone info
Tone1
704.0 Atone1
704.0Atone2
A Tone Found! 10:10:38
1359303038.18
Checking for B Tone 10:10:38
2.8 10:10:41
1359303041.16
done sleeping at 10:10:43
1359303043.75
pre-record
1359303043.76
post-record
1359303043.94
Checking for B Tone2 10:10:43
1359303043.94
747.0
Tone Set Found! 10:10:43
1359303043.94
ValleyMills[4] 10:10:43
******@*****.org,*****@*****.org
delay timer ValleyMills[4] 10:10:43
waiting for audio ValleyMills[4] 10:10:50
recording audio ValleyMills[4] 10:10:50
done writing WAV ValleyMills[4] 10:11:18
ffmpeg version N-32726-ga254452, Copyright (c) 2000-2011 the FFmpeg developers
built on Sep 19 2011 19:49:13 with gcc 4.6.1
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --ena
ble-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-
libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --ena
ble-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --en
able-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis
--enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 16. 1 / 51. 16. 1
libavcodec 53. 16. 0 / 53. 16. 0
libavformat 53. 12. 0 / 53. 12. 0
libavdevice 53. 4. 0 / 53. 4. 0
libavfilter 2. 43. 2 / 2. 43. 2
libswscale 2. 1. 0 / 2. 1. 0
libpostproc 51. 2. 0 / 51. 2. 0
[wav @ 00398880] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 00398880] max_analyze_duration 5000000 reached at 5015510
Input #0, wav, from './audio/ValleyMills[4]_2013-01-2710_11_18_053000.wav':
Duration: 00:00:27.86, bitrate: 176 kb/s
Stream #0.0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 11025 Hz, 1 channels,
s16, 176 kb/s
[mp3 @ 030AC960] Unsupported sample rate.
Output #0, mp3, to './audio/ValleyMills[4]_2013-01-2710_11_18_053000.mp3':
Metadata:
TSSE : Lavf53.12.0
Stream #0.0: Audio: mp3, 11025 Hz, 1 channels, s16, 24 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (pcm_s16le -> libmp3lame)
Press [q] to stop, [?] for help
size= 82kB time=00:00:28.00 bitrate= 24.0kbits/s
video:0kB audio:82kB global headers:0kB muxing overhead 0.039281%
done converting to MP3 ValleyMills[4] 10:11:18
File "<string>", line 447, in mail
tect58b_debug\outPYZ1.pyz/smtplib", line 242, in __init__
error: [Errno 10013] An attempt was made to access a socket in a way forbidden b
y its access permissions
[wav @ 00288920] parser not found for codec pcm_s16le, packets or times may be i
nvalid.
[wav @ 00288920] max_analyze_duration 5000000 reached at 5015510
s16, 176 kb/s
Output #0, amr, to './audio/ValleyMills[4]_2013-01-2710_11_18_053000.amr':
Metadata:
encoder : Lavf53.12.0
Stream #0.0: Audio: amr_nb, 8000 Hz, 1 channels, s16, 10 kb/s
Stream mapping:
Stream #0.0 -> #0.0 (pcm_s16le -> libopencore_amrnb)
size= 37kB time=00:00:27.88 bitrate= 10.8kbits/s
video:0kB audio:37kB global headers:0kB muxing overhead 0.015941%
done converting to AMR ValleyMills[4] 10:11:20
699.0 Atone1
618.0Atone2
  #1219 (permalink)
Old 01-27-2013, 5:46 PM
My apologies. TTD was being blocked by my antivirus.
  #1220 (permalink)
Old 01-27-2013, 10:07 PM
Default v59 Released - for testing only
Hi everyone,
I just posted v59 on the program page, and I'm looking for some people experienced with TTD to help test it. This version uses a completely different algorithm for tone set detection. I think it should be pretty robust and should solve the few remaining problems that the previous algorithm had under some specific situations. When I get a chance I'll post a graphic that shows the difference between the two algorithms. With the v59 algorithm, an Atonelength can be specified as an optional parameter. You'll need to do this via manual tones.cfg file editing, as the TonesEditor doesn't yet have this added. If nothing is specified it uses an Atonelength of .4 seconds (same as prior versions). Also, v59 doesn't use Btonedebounce or Longtonedebounce...the debounce is equal to the tone length. The graphic should make this clearer. In the meantime, give it a shot and let me know how it works, especially in stacked page situations or situations where you've had issues with the prior algorithm either falsing or not detecting pages.
If the feedback on v59 is good, all future releases will use this new algorithm, including the Raspberry Pi version. BTW, making good progress on the Pi, my previous issues seemed to be solved by switching to a different (although more expensive) USB sound card.
Thanks,
Andy
Tags
twotonedetect
