Finally Found Source of interference in Feed
Ben96cal
Livermore, Ca
For those of you who have had interference/white noise on your feed and have never found out why you can try another avenue.. I've had interference in my feeds for awhile now where one scanner's traffic will show up on another and they aren't even being fed on the same PC. Well after exhausting everything I thought could be the issue I unplugged the USB programming cable from my laptop that was plugged into one of the offending scanners and poof the interference was gone.. I can't beleive power from the USB cable was causing this.
