Running two unique feeds on the same PC, both through identical USB adapters and both going out via OddCast v3. On Oddcast, the audio from only one feed is appearing on both feeds at their mountpoint. It appears that Oddcast sees and names both USB adapters the same name. Does Oddcast have issues with multiple USB adapters?
FWIW - I also have Scannercast v 0.14 running the same feeds and it has no problem recognizing each of the identical USB adapters as unique...
