McP
I'm in the process of setting up my first stream. I have everything in place, just waiting on the approval from RR and I'll be using ScannerCast.
Searching the forums, I found information on audio cables and setting up scanner to PC.
I've read some recommendations for the RS 42-2420
Search Result
and the set up listed here on the Wiki...
Setting up your Broadcasting Station - The RadioReference Wiki
I am using a Uniden 996XT scanner and was hoping to get specific information to my connections. I'm not sure if I have to have ScannerCast running after approval of my feed or not to test my connection, but so far I can't find a way to do so.
I've tried the "rec" jack on the back of the 996XT (I assume I don't use the external speaker port on it.
And I've tried running that cable to the "line in" on my sound card and the "mic" with no luck. Or at least no way of seeing if my feed will be listenable once I'm approved. I've done the set up on the Wiki as well as using the 2420 cable as someone mentioned in a similar thread to another person.
I'm guessing I can't tell if it's working or how it sounds until I can connect with ScannerCast after I am approved.?.
Search Result
