Old 02-13-2012, 3:25 PM
Default Live Audio Feed ... Help
Trying to use BCD396-XT for live feed. This works thru microphone of PC but that's it. I thought it would run thru PC sound card and PC microphone would not be used. Am i'm configuring wrong????
Old 02-13-2012, 3:43 PM
ak4fn's Avatar
You need to have a data cable and an audio cable. There seems to be a general misconception that audio will go through the data cable. Not sure if this is what you are asking or not.
Old 02-13-2012, 3:50 PM
frazpo's Avatar
You need an audio cable attached between the scanner and your MIC port on your sound card. Some use "line in". I have used both. I am a little confused by what your asking? Do you have both a PC mic and a soundcard mic ?
346XT 396XT 890XLT various older models
Southwest Missouri - Joplin Area
http://www.mokanscanner.com
Follow Me On Twitter - http://twitter.com/stormwx
Old 02-13-2012, 3:52 PM
OK ....... So, the cable that connects the BCD396-XT to the computer and runs the software programs isn't enough to do the data and audio? Sorry, but I'm really only learning this stuff.
Old 02-13-2012, 3:56 PM
ak4fn's Avatar
You are correct, you need 2 cables one that does the software/programming/data and one cable for the audio.
Old 02-13-2012, 3:59 PM
frazpo's Avatar
I do not have that setup but I do not believe so. None of the instructions indicate that. I believe you NEED an audio cable no matter if you have the data cable or not.
No apologies, we all learned at some point.
Old 02-13-2012, 4:01 PM
OK..... thanks a lot. Just hooked up the audio cable and seemds to be working correctly now.
Old 02-13-2012, 4:04 PM
frazpo's Avatar
Sounds really good.
