Old 12-03-2012, 7:21 AM
kg4pbd's Avatar
Default Four scanner streams via one PC
Can anyone give me an idea on how (or if) I can run four audio streams on a single pc? Running four instances of Proscan is easy enough but trying to separate audio streams beyond my ability. Is it even possible?
Thanks,
Scott, kg4pbd
Old 12-03-2012, 7:41 AM
Tryton's Avatar
You need to have 4 sound cards or usb sound cards. I currently run 2.
Equipment: Uniden Bearcat BCD996XT X 2
________________________________
K1SPL
Old 12-03-2012, 8:16 AM
I'm doing it with 3. I'm using cheap ebay USB sound cards. The only hassle is that the sound cards show up in windows with the same device name so sometimes it's hard to keep them straight.
Lots of radios, not enough antennas...
Old 12-03-2012, 2:01 PM
Send a message via AIM to IAmSixNine Send a message via Yahoo to IAmSixNine
Im running 5 on a netbook at my apt.
Takes a while to configure the sound profiles for each USB sound card but it does the trick.
I picked up a 6 port USB hub with external power supply as well.
Old 12-03-2012, 8:57 PM
Live Audio Administrator
I used to provide 8 feeds from a single computer by installing two M-Audio Delta 1010LT cards in the same computer (each card gives you 4 stereo inputs), they're designed to allow you to have up to four of them installed in the same computer.
Listen to RadioReference.com's online scanner feeds on your iPhone or iPad using Scanner Radio Deluxe or on your Android phone or tablet using Scanner Radio.
Old 12-03-2012, 9:09 PM
NYRHKY94's Avatar
I'm running 5 of my 7 feeds from a Dell GX270 Tower using multiple PCI sound cards, including the M-Audio Delta 1010LT that Gordon posted about.
PSR600/PSR500/PSR410/PRO106x2/PRO197x3/PRO2096/BCD996T/BC796D
BCT15X/BC898T/HP-1/BC210XLT
Feeds: http://www.radioreference.com/apps/account/?tab=la
Old 12-03-2012, 9:10 PM
nunyax's Avatar
I run 8 feeds on one PC (onboard sound, 3 PCI sound cards and 4 cheap USB sound cards on a USB hub.) Works fine.
73 de KQ4XL
Joe
Just one of the "little scanner people."
Old 01-06-2013, 11:46 PM
W5JER's Avatar
You can rename them in Deice Manager.
Radios: IC-7000 | Yaesu FTM-350 | Yaesu VX-8DR | Baofeng UV-5R | Baofeng UV-5RA | Baofeng UV-5RC | Baofeng UV-3R | Cobra 29 LC CHR LE
Scanners: GRE PSR-500 | BCT15X x3 | BC370CRS
Old 01-14-2013, 9:53 AM
ve3nsv's Avatar
Send a message via MSN to ve3nsv
A machine running ESXi with 4 virtual machines and 4 USB sound cards.
Old 01-21-2013, 4:11 PM
c5corvette's Avatar
Can you tell everyone how you do that? Do you add and rename one at a time and then do the next one?
Please spell it out for the Streaming For Dummies book is not yet available at my bookstore.
FREE Interop:
1. Pre-program agency radios with all national interoperability channels and frequencies.
2. Share radio frequencies / talkgroups with neighboring agencies on compatible radio systems.
