dmobile1337
I have seen this question posed before but I either haven't seen any answers to this question or the answer was from 2011 or earlier and things may have changed since then.
Right now I am using K1PGV's quite excellent utility ScannerCast to stream my scanner to RadioReference which I downloaded from his site, not from RR. I have the extreme upgrade and a USB cable plugged in, as well as the HomePatrol USB Serial port driver installed. Scanner cast sees the available COM port and I am able to select it.
I have two questions at this point. The first question, is there a way to broadcast the system/TG info with the audio to RR using the HomePatrol? My second question, does ScannerCast support that at this time?
