Alpha Tags
Lexxx
Kitchener, Canada
I currently stream 4 feeds to RR. I use Simplecast an Icecast server and let RR access my Icecast server at 4 mount points for the feeds.
I'm thinking of trying Scanner Cast and would like to generate Alpha Tags on an embedded player on the web site I run
I already have the RR embedded player on different pages for my 4 different feeds, but need to know if there is some way to embed a Java player, or some kind of player in my web pages to show tags matching the audio.
I've read what I can from the info on this site and the Scanner Cast info does imply I can use alpha tagging for the BCD996T and the two BCT 15s I have. I'm sure the alpha tags will work on the RR site (or Broadcastify site), but I want the tags to work on the pages on my site.
Does RR/Broadcastify have a player (the code for the player) that will display tags that I can embed in my web pages?
Peter
