Winamp disconnects after a period of time
johnmac
Westminster, Ma
I am using winamp to monitor to of my RadioReference feeds locally on my LAN. Connection drops after a few hours or less.
The set up is follows -
I am using RadioFeed to stream to radio reference and also using the webserver portion of RadioFeed to listen locally on my laptop. Laptop is Windows 8 64bit.
I have two instances of Winamp running on my laptop connected to the webserver(s) locally. The laptop is wireless. Also two instances of RadioFeed are running on the feed computer streaming two separate scanners. Feed computer is wired to the network.
I believe that this is some issue with the laptop, but not sure. Any thoughts??
Thanks,
