  #201 (permalink)
Old 05-17-2018, 11:54 PM
davidVT's Avatar
Originally Posted by DC31 View Post
Attached is a screen shot showing what you are looking for. This one is for a tone set of 322/338. Until TTD starts receiving audio with tone indications like this, it won’t decode. Perhaps you need to adjust your scanner volume or otherwise improve the audio.
I don't think the radio audio is reaching TTD. As a test, can you switch the radio to a weather channel and then see the TTD data scrolling start and stop when you turn the weather channel on and off?
  #202 (permalink)
Old 07-03-2018, 10:42 PM
Default Audio not feeding to two tone detect
When I try to play a audio file from my computer it does not seem to pickup on Two tone detect.
Any Suggestions??
firefighter2254
  #203 (permalink)
Old 07-04-2018, 3:30 PM
Any Suggestions??
firefighter2254
You will need to describe your setup in more detail for us to be of much help. How are you “playing” audio on your computer and expecting TTD to hear it?
  #204 (permalink)
Old 07-04-2018, 3:54 PM
DC31 Thanks for the info I just saw this I will try this and let you know Thanks again fire701
  #205 (permalink)
Old 07-05-2018, 9:37 AM
I have a radio that is plugged in to the audio jack. I have messed with the audio defaults but still nothing.
  #206 (permalink)
Old 07-06-2018, 4:22 AM
First, prove that audio is getting to your computer. Open the squelch or set the radio to the weather channel and see if you can get audio out of the computer speakers. You will need to cross this hurdle before anything else will work.
  #207 (permalink)
Old 07-09-2018, 2:21 PM
Default Sound issues w/ v70
Hello! We purchased a Lenovo laptop running Windows 10 w/ a combo microphone/speaker jack. We have installed the plug to separate the two jacks so the computer is not using the internal webcam mic.
The mp3 files are extremely distorted and quiet. Any suggestions?
  #208 (permalink)
Old 07-10-2018, 8:22 PM
I opened the squelch and have little bits of audio but that is it
  #209 (permalink)
Old 07-10-2018, 8:36 PM
Check all of your audio cable connections and your scanner volume.
  #210 (permalink)
Old 07-11-2018, 7:43 AM
The scanner is turned all the way up and the cable is brand new.
  #211 (permalink)
Old 07-12-2018, 12:22 AM
davidVT's Avatar
Firefighter2253,
Can you set the radio to a weather channel with known good signal and test the connections with that first?
  #212 (permalink)
Old 07-13-2018, 5:43 PM
after I figured out that it was my scanner I had to clean the antenna connector then it started to work again
Thanks for all of your help,
Firefighter2253
  #213 (permalink)
Old 07-30-2018, 3:36 PM
Default Bindings
Afternoon Gang,
I am running into this issue... Sometimes TTD will open as it should, and other times this will pop-up.
Does anyone know how to workaround and or resolve this issue?
Thank you.
Ryan S. Olsen
  #214 (permalink)
Old 08-06-2018, 6:37 PM
Default Having Trouble with my Two Tone Detect
Running Windows Xp on a Dell Computer
Sometimes it works but most of the time it does not I have attached screenshot of the program when it is receiving the tones but it will not start recording. It gets the two tones which are 650 and 607 but will not start recording. Any suggestions would be appreciated.
  #215 (permalink)
Old 08-06-2018, 9:44 PM
davidVT's Avatar
This may be down the wrong path but...
Can you hear this on the pic speaker while being processed?
I ask because the squelch seems set very high. I am curious if the audio is breaking through..
The numbers on the terminal suggests it is but I thought I would ask.
  #216 (permalink)
Old 08-06-2018, 9:46 PM
davidVT's Avatar
Ryolsen8,
Any chance you are trying to run it a second time while it is running in the background?
  #217 (permalink)
Old 08-07-2018, 12:25 AM
To start try turning the scanner volume, mic/line in volume and in gain levels down, the audio spike seems really high
Second older dell sound cards are good to go bad. You can order a usb audio card for like 10 bucks and ttd loves them.
Third check your settings related to recording you didnt post any pictures of your settings pages...
But that's where I would start
  #218 (permalink)
Old 08-08-2018, 9:08 PM
Originally Posted by Coolant113 View Post
Okay so first time attempting to use two tone detect and I have no idea what's going on with the software. I downloaded the latest version and entered all the tones I want it to pick up. Not a minute after I was done doing that the software crashes. When I try to reopen it, the program goes "not responding" immediately. I am running the application from the folder that I downloaded it to, because it does not come with an installer. Which leads me to my next question, how do you install it properly? I am so confused and frustrated with it so I'm turning to the forum in a last ditch effort to figure it out before I abandon the software all together.
Thanks in advance!
I'm new at all of this but we had to change our email password and every thing seems to work but we get lots of DOS windows wanting to know if we want to overwrite ffmpeg.exe with every page. Not to sure what to do or not do. Didn't see any thing in the logs. Thanks
Dan
  #219 (permalink)
Old 08-09-2018, 2:07 PM
DavidVP and Nated1992
Thanks for the help I changed to USB card and it worked that time. Will see how it does next time. Thanks
  #220 (permalink)
Old 08-09-2018, 3:13 PM
Dan
Can you post pictures and logs?
