  #221 (permalink)
Old 08-09-2018, 5:04 PM
Originally Posted by davidVT View Post
Ryolsen8,
Any chance you are trying to run it a second time while it is running in the background?
I don't believe it is..
Ryan S. Olsen
  #222 (permalink)
Old 08-11-2018, 5:55 PM
Now I have usb card working and got the audio to low. How do I turn it back up. I have tried the microphone setting and it does not seem to help.
  #223 (permalink)
Old 08-11-2018, 6:07 PM
Put the mic setting at about half way, then slowly increase the volume from the scanner
  #224 (permalink)
Old 08-11-2018, 6:24 PM
Got any more suggestions it did not move. I know I am getting audio to the computer because it is live feed and I can hear it when I key the mic.
  #225 (permalink)
Old 08-12-2018, 7:27 AM
Does your speakers have volume control, check all your software defined audio controls and if the usb audio card has volume on it
  #226 (permalink)
Old 08-12-2018, 1:05 PM
I turned the speakers up, I turned up the volume on the usb card, I went in to the audio control and turned them up, I noticed that after I went in to the radio feed program and got it to working that is when my audio went down to nothing on my Two Tone Detect software. I am attaching a screenshot of this for you to look at.
I checked the cord that sends the audio from scanner to usb card and it was working.
  #227 (permalink)
Old 08-12-2018, 1:34 PM
When there is audio coming from the scanner does the audio level "green bar" move... it may not be low audio as much as not having back ground or computer noise entering in the stream routed to two tone detect. How's the audio on your scanner feed? If its reasonable? If so adjust the squelch on two tone down to just above the green line with no audio being sent and that should be good
  #228 (permalink)
Old 08-12-2018, 1:50 PM
I will check this and get back with you Thanks
  #229 (permalink)
Old 08-13-2018, 10:00 PM
Did that solve your problem?
  #230 (permalink)
Old 08-15-2018, 6:47 AM
I think so I will check on the next test and see. Thanks
  #231 (permalink)
Old 08-15-2018, 8:18 PM
Originally Posted by nated1992 View Post
Can you post pictures and logs?
Well it has stopped doing it, nothing changed after we changed the email password and it has worked great. Thanks anyway I do appropriate it
