  #321 (permalink)
Old 06-09-2014, 9:37 AM
Originally Posted by krokus View Post
What type (s) of distortion? I could see audio levels being a problem, or "frame loss" due to over taxing a low end processor.
Sent via Tapatalk
It sounds so garbled. Take a listen if you like you will notice who the state police digital feed right away.
http://www.broadcastify.com/listen/feed/14920
  #322 (permalink)
Old 06-13-2014, 11:46 PM
Hey im wonder if this is possible
I want to have a lcd that displays the last page out time and have a relay powering a 12v led light
Ik how to program it but the lcd and relay require the 5v pin on the rPi
I rather not have to use a external power to trigger the relay if any one can help that would be great since im not good with electronics
  #323 (permalink)
Old 06-14-2014, 3:34 AM
krokus's Avatar
Add a script, which calls a program to display the current time on the display, and turn on the lamp.
Sent via Tapatalk
  #324 (permalink)
Old 06-14-2014, 4:27 AM
Get yourself a Sainsmart 4 relay board off Amazon for about $9. Wire it to your pi as shown in the image at: Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting Make sure that you remove the jumper across VCC/JDVCC. That utilizes 5 v. to pull the relay in and 3.3 v. to control it. The 5v and 3.3v are separated when the jumper is removed. I have one set up this way and it works like a charm. Some posts talk about exceeding the amp capacity of the pi's 5v. pin if all relays pull in simultaneously. It sounds like you only need one relay, though. Attached is a photo of mine.
You can easily call your python script from the alert_command parameter. Make sure that the script or program is accessible from the folder that TTD is running from. Then it would be something like: alert_command = sudo python blink.py
  #325 (permalink)
Old 06-14-2014, 4:42 AM
Sent via Tapatalk
Here is a better image of how to hook it up with the jumper removed:
http://img33.imageshack.us/img33/1010/uk1a.jpg
Note that the 5v. pin on the pi goes to the JD-VCC pin with the jumper removed.
The whole post:
Raspberry Pi • View topic - GPIO to SainSmart 4-channel relay board, transistors needed?
  #326 (permalink)
Old 06-14-2014, 5:58 PM
I under stand how to hook up a relay now but im still a little puzzled
Adafruit RGB Negative 16x2 LCD+Keypad Kit for Raspberry Pi:Amazon:Industrial & Scientific
this is the lcd im using it looks like it uses all the gpio pins but im not sure
Also if it dosnt use all the pins can I use pin 2 (5v) to power the lcd and pin 4 (5v) for the relay and would I just extend pin 4 threw the lcd board
  #327 (permalink)
Old 06-25-2014, 8:46 AM
Default Problem setting up on PI
Here is a screenshot of the problem that is occurring, everything is setup and configured. When I launch the twotonedetect60api.py program it gets to the point of 'audio_threshold' is not defined, and that is it. Any Ideas on what to do to fix this issue?
  #328 (permalink)
Old 06-25-2014, 8:31 PM
Don't you just love those error messages that point you right to the source of your problem?
I think that I have had this one in the past and it indicated that my Base64 encoded password was not correct in the Config.cfg file.
See TwoToneDetect on a Raspberry Pi - How To
  #329 (permalink)
Old 06-26-2014, 5:23 PM
What should the Base64 encoded password be?
  #330 (permalink)
Old 06-26-2014, 8:30 PM
It is your gmail login password (or other email provider) encoded as Base64.
To encode your password go to Base64 Decode and Encode - Online. Then copy and paste the result into the password entry in config.cfg.
If you encode the word twotonedetect it returns dHdvdG9uZWRldGVjdA==
  #331 (permalink)
Old 07-09-2014, 6:51 PM
I purchased an imic external speaker and that fixed the issue
