jonathon6017
- Joined
- Aug 15, 2012
- Messages
- 2
Hello Everybody, I was wondering if you could help me decipher what the heck is up with my installation. I have played with this thing on three different machines with the scanner being in three different areas and I could not get it to work. I tested all these machines out by playing the correct tones over FRS channels and allowing the scanner to listen in on that. Every time I did that, it ran fine and picked up tones perfectly. However when switching over to the main channel our Department uses for Dispatch, I ran into issues. The first machine I tested, I had the radio in a location that wasn't allowing it to pickup very well so that was part of the issue. However one thing I noted was that the audio levels are not really high like they are on the other two machines. On the second machine, I had high audio input levels and it wouldn't pick up any tones. I wondered if it was the radio but I left the scanner unplugged for multiple days and it picked up just fine. It's just that the computer doesn't detect the tones for some reason. On the second machine that I installed it on, the same issue happened; good location, scanner listens well, but no detecting. I attached links to show what I was talking about with the audio levels. I also attached Google Drive links to my log file and my Tones.cfg(NOTE: I removed email info for privacy concerns)
Radio Scanner Test (Two Two Detect Version 61) - YouTube
https://docs.google.com/document/d/12L2rqBw_hpQJ5ga2ArG1vJ1aYRmHGyWponbJC4flC7Y/edit?usp=sharing
https://docs.google.com/file/d/0B8d1Ix3fDtIjU3pFa2dtUXg0bVE/edit?usp=sharing
