Old 04-19-2014, 1:11 PM
engineer69's Avatar
Default Com Ports on BCD536HP
I am trying to get the alpha tagging working on my Broadcastify feed. I am using a double male USB cable to the rear of the radio. It will not recognize it I have gone into the radio settings and set the location,GPS Set up, Serial Port Setting, 115200bps. It still wont work. Any help. Please
Old 04-19-2014, 1:49 PM
What broadcasting software are you using?
Sent from my SPH-L710 using Tapatalk
Old 04-19-2014, 1:53 PM
engineer69's Avatar
Scannercast
Old 04-19-2014, 4:07 PM
I'm not sure if Scannercast supports the new scanners yet. Maybe the author can chime in.
Old 04-20-2014, 4:18 PM
I think you have to use the front USB port.
Old 04-20-2014, 5:13 PM
ProScan's Avatar
The software has to support the BCDX36HP for the text tags to work. My free RadioFeed does that. If using the rear port then you will need a null modem adapter (pins 2 and 3 rolled).
