Originally Posted by kr0490
Where in the program do you set the audio device to record from?
Are you setting up a ProScan Remote Scanner Over IP server and the free ProScan Client to listen to the server audio?
If using the free ProScan client then there is no setting as the Recorder records only the incoming audio from the internet and not from the sound card.
If using ProScan then go to the "Audio Control" tab and then the "Recorder" tab to select the input.
