Radio Feed software
AC0RV
Park Hills, MO
Ok, I know you can stream the Unit Ids using this %U. But how can use stream the Alpha tags for the unit ids ?
eaf1956
Evansville, IN
Metadata Source
With ProScan you have to add it in your METADATA Source. That tells it what information you wish to send as a TAG. With Radio Feed it's under the METADATA tab.
AC0RV
Park Hills, MO
Ok I see where you can add the ID (5123), But not the Alpha tag. How do I add it to show only the alpha.
I am using a 436HP with the Senital software.
Please help and like always I thank you.
AC0RV
Park Hills, MO
I still need help in sending the alpha tags for the radios instead of sending the UID #s
Thanks.
W8RMH
Feed Provider Since 2012
Grove City, OH (A Bearcat not a Buckeye)
On the DMA scanners you create a group of Unit IDs/Alpha tags. Enter the ID as i5123 where you would normally enter the TG, then assign it an alpha tag.
Does Sentinel have something similar, maybe in a favorites list.
