Old 08-16-2014, 11:32 AM
MedicDavid78's Avatar
Angry ScannerCast & BCD536HP...
Is there a way to broadcast AlphaTags in ScannerCast using a Uniden BCD536HP?? I've downloaded the serial port files, rebooted my computer, even set the scanner in serial mode & set the Tag setting at the 996XT choice, even saw something about Windows Device Manager up checking the UBS root hub thing... Now when I choose the correct Com Port in ScannerCast it shuts down on me everytime! I've seen to try RadioFeed and can't get it working there either... Does ANYBODY else have a BCD536HP and broadcast AlphaTags that can lend me a hand? Thx!
Old 08-16-2014, 7:07 PM
I'm out of town and it has been several months but if I remember correctly I used the serial port and had to get into the 536 menu under the set location, set up gps, set serial port, set the correct baud rate for your computer connection.
Let me know if it works, otherwise I can check when I get back in town.
Old 08-16-2014, 7:35 PM
The only problem is I'm not using the Serial port I'm using the front port to USB...
Real-Time news alerts covering Mecklenburg, Gaston, Lincoln, & Catawba Counties!
Metrolina Alerts Facebook
Metrolina Alerts Twitter
Old 08-16-2014, 11:25 PM
As far as I know, it will not work that way.
Old 08-17-2014, 10:52 AM
Hmmmm okay so basically I need to buy a serial-to-USB cable, I think Prolofic makes a good ones I've used before with another scanner...
Tags
alpha tags, bcd536hp, broadcast tags, uniden
