VB-cable volume control
rcummings14
clarksburg wv
Is there any way to adjust the volume for vb-cable that is feeding dsdplus besides using windows volume controls. I have excellent signal but still get errors in dsdplus. My volume looks to be peaked out but no matter how low i set the volume in windows it stays the same. any help would be much appreciated.
Voyager
If you are using SDR#, install the DSD Interface plugin. It has an independant volume control for feeding DSD+.
D
DaveNF2G
Guest
I think you're stuck with Windows volume controls in that situation. You'll have to set the playback volume for the VB cable there.
Voyager
You can also use SDR# with the aforementioned plugin for separate Virtual Cable and Speaker controls. (or ask the Unitruinker author to add a Virtual Cable output control)
rcummings14
clarksburg wv
After searching and coming up with nothing. I figured out a solution to my problem. I was able to download voice meeter from v-b cable website. I ran my signal from unitrunker through the software and was able to lower the db level. dsdplus now running with virtually no errors.
