adacats
Scanner and Train Nerd
So I currently use the web server feature of radio feed so I can listen to my scanner while at work. Now to make it work the port im using has to be forwarded on my router. Next year I will be moving into an apartment that only provides complex wide wifi. So my question is, is there anyway to run my webserver when I can't forward ports, or is there an alternative to provide a private feed on public wifi?
