Hi,
I am trying to start up a broadcast from my Mac laptop and I'm having some trouble. I am a bit of a newbie so you will pardon me for eventual stupid staff I might ask
I am using Sunflower, Jack Osx, Darkice and Icecast.
I think I've done everything right but my problem now is that I can't start Darkice without getting this error message:
Tametos-MacBook-Pro:etc Tameto$ darkice -c darkice.cfg
DarkIce 1.2 live audio streamer, Google Code Archive - Long-term storage for Google Code Project Hosting.
Copyright (c) 2000-2007, Tyrell Hungary, Tyrell Hungary Corporation
Copyright (c) 2008-2013, Akos Maroy and Rafael Diniz
This is free software, and you are welcome to redistribute it
under the terms of The GNU General Public License version 3 or
any later version.
Using config file: darkice.cfg
Using JACK audio server as input device.
POSIX scheduling not supported on this system, this may cause recording skips
unknown option character l
connect(2) call to jackdmp 1.9.11/jack-502/default/jack_0 failed (err=No such file or directory)
jackdmp 1.9.11
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2016 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
self-connect-mode is "Don't restrict self connect requests"
2016-04-21 20:15:55.578 jackd[813:15834] 20:15:55.578 WARNING: 140: This application, or a library it uses, is using the deprecated Carbon Component Manager for hosting Audio Units. Support for this will be removed in a future release. Also, this makes the host incompatible with version 3 audio units. Please transition to the API's in AudioComponent.h.
Input channel = 0 ==> JACK input port = 0
Input channel = 1 ==> JACK input port = 1
JACK output port = 0 ==> output channel = 0
JACK output port = 1 ==> output channel = 1
CoreAudio driver is running...
attempt to connect to server failed
DarkIce: JackDspSource.cpp:216: JACK server not running? [0]
No idea where to start finding the fault, any help much appreciated
Thanks,
Tameto
any later version.
jackdmp 1.9.11
Thanks,
Tameto
