It appears the forum owners have not yet allowed you to receive messages, so here's the detailed part.
After you get all of this setup, it will record 3 hour files in a 11kHz low variable bit rate mp3 quality, and with Windows Task Scheduler, we'll try to make sure it stays going. The file names will be the date and time of the beginning of the recording.
Download 7-Zip. This will allow you to extract the files. It's a very good packaging program. You could also use it later on to archive your old recordings.
7-Zip
Download FFmpeg. Figure out whether your computer is 32 or 64 bit (go to Control Panel -> System; under the System subheading in the new window, there should be a line for "System Type"). Download either the 32 bit or 64 bit static version of the software (top row on the page with two columns).
https://ffmpeg.zeranoe.com/builds/ Extract the file. Move the contents to C:/Radio Traffic (a folder you should create). Rename the long folder name to "FFMPEG". In the Radio Traffic Folder, make a new folder called "Recordings". Note: You can do this in other folder locations, it will just mean the script will have to be modified.
Tell the program what to do. In the Radio Traffic folder, make a new "Text Document" (right click, go to new -> Text Document). Open it and copy and paste the following:
@echo off
cd "c:/Radio Traffic/FFMPEG/bin"
title Radio Traffic Recorder
:start
echo New recording session started...
ffmpeg -f dshow -i audio="Line In (Realtek High Definition Audio)" -t 43200 -acodec libmp3lame -ac 1 -ar 11025 -aq 7 -f segment -segment_times 10800,21600,32400 -strftime 1 "c:\Radio Traffic\Recordings\DispatchArchive_%%m-%%d-%%Y_%%H%%M%%S.mp3"
goto start
Save the text file as "RecordRadio.bat" and change the file "Save as type" to "all files". You should now have a "Windows Batch File" instead of a notepad document.
Next, make sure your radio is connected to the line in port of the computer. Set the volume about 3/4 of the way. Tweak it in the future to find a good level that is clear and doesn't distort yet is not too quiet. If you have a different audio driver or a different name for your input, we'll have to modify the script to account for that.
If you are lucky, after that, double click on the RecordRadio.bat file you made, and it should start recording. You can create a shortcut to that file.
If you decide to go this route and make it this far, I'll send you info about scheduling a task in Windows after we get this working properly. Let me know if you have any questions. I left this running overnight scanning my radio, and it seemed to work well. I can't be held accountable for it or any failure, though.
Hope this helps you accomplish your goal.
Justin
