Hello,
I am new to the forum. I would like to feed data using a Raspberry Pi. I am looking at this on URL Raspberry Pi RTL-SDR Broadcastify - The RadioReference Wiki , to set this up. Everything seems pretty easy to do. But I'm not sure what I need to do with the following part.
Create the following configuration file at /etc/ezstream_bcfy.xml and replace with your mount, password, and stream name. If you plan on having multiple streams make sure and create a separate named configuration file (i.e.'/etc/ezstream_bcfy2.xml) for each stream and reference accordingly in your command script below.
<ezstream>
<url>http://audio#.broadcastify.com:80/your_mount</url>
<sourcepassword>your_source_password</sourcepassword>
<format>MP3</format>
<filename>stdin</filename>
<svrinfoname>Stream Name</svrinfoname>
<svrinfourl>http://www.broadcastify.com</svrinfourl>
<svrinfogenre>Scanner</svrinfogenre>
<svrinfodescription></svrinfodescription>
<svrinfobitrate>16</svrinfobitrate>
<svrinfochannels>1</svrinfochannels>
<svrinfosamplerate>22050</svrinfosamplerate>
<svrinfopublic>0</svrinfopublic>
</ezstream>
I know how to make the file and save it. But I'm not sure what "mount" and "stream name" is. Can anyone help me with this? I would like to get one feed setup and running. Thanks.
<ezstream>
</ezstream>
