Old 05-11-2017, 4:24 PM
Nate1n22's Avatar
Default Why does my feed sound like this?
About every 30-45 minutes my feed will go completely unintelligible. It will slowly get worse for about 2-3 minutes then go back to normal.
Anything I can change to stop this?
Here's an audio sample:
https://streamable.com/5lm8m
Old 05-11-2017, 5:12 PM
Bubba1661's Avatar
WV DB Admin
That's wierd, sounds like bleed over. Can you tell what agency is talking?
Bubba1661
West Virginia Scanner's Group
Old 05-11-2017, 5:24 PM
blantonl's Avatar
Founder and CEO
What are you using to broadcast your feed?
Lindsay C. Blanton III
CEO - RadioReference.com / Broadcastify
Facebook: RadioReference | Broadcastify | Twitter: @RadioReference
Old 05-11-2017, 7:07 PM
ProScan's Avatar
It sounds like you are overdriving the sound card. Is the scanner volume way up? I would turn it down and turn up the sound card input.
Old 05-11-2017, 9:27 PM
Nate1n22's Avatar
I just have 1 agency being broadcasted.
Nicecast.
The volume is about a 1/4 past completely muted. I'll try lowering it.
Old 05-12-2017, 1:48 AM
krokus's Avatar
How does the audio sound, coming out of the radio?
Sent via Tapatalk
Old 05-14-2017, 6:27 PM
Nate1n22's Avatar
Sent via Tapatalk
Sounds fine. I am using one of the USB soundcards. I'm wondering if that's causing it.
Old 05-16-2017, 4:18 PM
I use to have issues similar to this when I use to use NiceCast. Nothing was ever explainable for as to why the issue was occurring. NiceCast has a mind of its own.
North Jersey BC 996XT | BC 996P2 | 3 X BCT 15X | WHISTLER TRX - 1 | WHISTLER TRX - 2 | BC 346XT | BC 780XLT | 3 X BC 355 | RS Pro 405 | Pro 135 | PRO 2050
