Old 05-15-2017, 8:26 AM
ProScan's Avatar
Default RadioFeed
RadioFeed Version 4.1 Just Released
What's New
  • Fixed - Web Server Metadata Delay setting was changing the Delay on all Web Browser instances.
  • Fixed - Web Server - Edge and IE browsers cosmetic problem.
  • Fixed - Source Client intermittent disconnects.
  • Fixed - Source Client Auto Reconnect wasn't working if connection was lost.
  • Many more small improvements.
Text Tags supported for the BCT8, BCT15, BCT15X, BC250D, BC296D, BR330T, BC346XT, BC346XTC, BCD325P2, BCD396T, BCD396XT, BCD436HP, BCD536HP, BC780XLT, BC785D, BC796D, BC898T, BCD996T, BCD996XT, BCD996P2, HomePatrol, PRO18, PRO106, PRO107, PRO197, PRO652, PRO668, PRO2052, PSR310, PSR410, PSR500, PSR600, PSR800, WS1040, WS1065, & WS1080 scanners.
RadioFeed and ProScan are the most powerful and feature rich scanner streamer software in this world.
RadioFeed Setup Instructions - The RadioReference Wiki
Old 07-30-2017, 12:21 PM
ProScan's Avatar
Default RadioFeed 4.2 Release
What's New In RadioFeed Version 4.2
  • Added- Metadata File Option to read all lines, 1st line, & last line
  • Fixed - Source Client Stream Name text box wasn't showing when set to Broadcastify.
  • Fixed - BCD536HP Wi-Fi Audio Gain 15 db wasn't consistent.
RadioFeed is the most feature rich scanner audio streamer software in the world, undisputedly.
Made in the USA
Old 08-03-2017, 2:21 PM
Wow! RadioFeed is awesome. Most of my feeds are remote and it's nice to the visual audio tools.
Can RadioFeed read Unitrunker TG from the log file and broadcast to Broadcastify?
Thanks,
John
Old 08-03-2017, 7:45 PM
ProScan's Avatar
RadioFeed can read text files. Go to Metadata tab and select file then select the 1st, all, or last lines. I'm not familiar with Unitrunker so you will have to look at the file and see where the talk group info is at.
Old 08-07-2017, 2:50 AM
One option is to use Trunking Recorder - Recording audio from trunked radio systems monitored by Unitrunker which can put the current talk group and radio ID in it's window title, which ProScan can read. UniTrunker can put info into a sdrsharptrunking.log text file (which Trunking Recorder uses), but with a lot of other text too.
Old 08-08-2017, 8:50 PM
ChrisABQ's Avatar
I just installed 4.2 and the metadata tags are not going to Radiofeed. I have a BCD436HP connected with serial cable, both Radiofeed and scanner set to com 3, rate of 115200. Scanner is not communicating with Radio feed at all. Audio is fine but I need some help with tags.
UPDATE: Change of USB port fixed the issue.
BCD436HP w/ProVoice & DMR - BCT15X (2) - UniTrunker DSD+ - Pro-2011(my very first radio) - Baofeng UV-5R
Old 08-09-2017, 5:46 PM
ChrisABQ's Avatar
I'm trying to use RadioFeed to broadcast my stream from a BCD436HP but the tags stop sending after a couple hours. I took over the feed from another provider that had his own BCD436HP and he did not seem to have an issue with tags stopping. What am I doing wrong, they literally stop sending after about 2 hours.
Update: Rolled back to 4.1 to see if there's a bug.
Old 08-11-2017, 11:34 PM
ProScan's Avatar
Did you ever get this resolved?
To isolate the problem, I would determine where you are losing the metadata.
Do you see the metadata displayed in RadioFeed? If no then a scanner to RadioFeed communications problem. If yes then the metadata is leaving RadioFeed and could be a server or media player problem.
Old 08-12-2017, 8:06 AM
ChrisABQ's Avatar
I was not able to resolve the issue, Scannercast worked and that's what is running now, tags and all. Been going for 2 days straight now, no issues.
I'm using an older windows 7 (64 bit) dual core computer with nothing else running but streaming software. I did find that the software began to "ghost" (able to see wallpaper image through the white areas of RadioFeed) after several hours, as if the program was becoming unresponsive.
Scannercast is running like a champ, no issues, no freezing.
Old 08-13-2017, 8:11 PM
ProScan's Avatar
I've been running RadioFeed a day and a half using the BCD436HP and don't see a problem. No one else reporting any problems either so I don't know why it's not working for you.
Old 08-13-2017, 8:28 PM
ChrisABQ's Avatar
No worries, must be a computer issue then.
Old 08-14-2017, 5:57 PM
What are the system requirements and platforms supported? Hard to tell from that webpage link. Does it work with Raspberry Pi's?
TIA.
Old 08-14-2017, 6:51 PM
TIA.
Pretty clear if you check the Frequently Asked Questions page:
FAQ
Q: Can you do a version for Mac, iPhone, iPad, Android, Blackberry, Raspberry Pi, Linux, etc.?
A: Negative. It will take several years to do each and I would rather spend the time on ProScan & RadioFeed.
