Old 01-12-2018, 9:54 AM
Default optimizing audio quality of my feed
Hi,
If this post is not appropriate in this forum section, feel free to move or delete.
I just yesterday got my first feed up and running. I'm using DarkIce on a Raspi with a conventional analog scanner (BCT8) with an audio cable into a USB sound card. Listening to the scanner audio directly, when there's no over air audio, (I've adjusted squelch) it's perfectly silent.
However over my feed I hear a faint, but steady popping or beating noise. I've messed with alsa input levels but that doesn't seem to matter.
Is this a noise issue between my scanner and USB soundcard, a software issue or something else?
Here's the feed in question.
https://www.broadcastify.com/listen/feed/27342
Old 01-12-2018, 11:16 AM
Chronic's Avatar
I have a sound on a feed and the popping sound is almost perfectly timed to the blinking light on the wifi / or network link light .
Old 01-12-2018, 12:02 PM
I'm using an external USB sound card with blinking LED. Maybe I should introduce a USB extension cable with ferrite beads. I found this helpful when I was playing with SDR dongles. Getting the receiver further from the laptop...
Old 01-12-2018, 12:32 PM
ChrisABQ's Avatar
I ordered this noise eliminator and it has virtually eliminated any background noise on my feed. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
BCD436HP w/ProVoice & DMR - BCD996P2 w/ProVoice - BCT15X (2) - UniTrunker DSD+ - Pro-2011(my very first radio) - Baofeng UV-5R/UV-82
http://abqscanner.com - https://dynodan.com
Old 01-12-2018, 7:00 PM
flythunderbird's Avatar
I had one of those $5 USB adapters from Amazon to use on my feed and while it did work, it put a lot of noise in the audio. I tried this and it fixed all of my noise problems:
https://www.amazon.com/Behringer-UCA202-BEHRINGER-U-CONTROL/dp/B000KW2YEI
I run it on a Windows-based thin client, but people have been using it with Linux for years.
Glenn
"Yeah, I have some radios ... I listen to some stuff ..."
Live Long and Monitor!
Old 01-12-2018, 8:12 PM
K9DAK's Avatar
Not sure if the Pi will run this... but I've used the Orban Loudness Meter for years with great results: https://www.orban.com/free-orban-loudness-meter/
Set the output level of your scanner maybe 20% below the point where it overdrives the sound card input, and lower the input level so the signal goes no higher than -3 dbFS on the PPM scale (read the Readme on the Orban website). That should give you the best S/N ratio.
Then, after a period of activity on your feed, download an archive mp3 file and look at it with Audiacity... you should see the waveform peaking at about 90% full scale.
This has worked great for my feed: Quad 3 and Lake Zurich Fire
Hope that helps...
Cheers and 73 de Dave, K9DAK
PRO-51, PRO-92, PRO-106, PRO-197, TRX-1, HTX-202, FT-530, TH-F6A, FT-8000, FT-847
Don't worry, relax, have a homebrew...
