Old 08-21-2018, 7:12 AM
Default Interference
My feed is setting a lot of buzzing and humming while Rxing, are you able to assist me?
Old 08-21-2018, 7:15 AM
jonwienke's Avatar
What scanner? If a Uniden, you need a ground loop isolator between the scanner and computer, or you will have all kinds of issues, up to and including burning out the amplifier.
Gone camping.
Old 08-21-2018, 7:22 AM
Yeah, a got ground loop isolator and the Scanner is plugged into a Raspberry Pi. Should I look that into the Pi does the direction of group loop need to be plugged into?
baj76's Avatar
in my opinion every scanner needs a ground loop isolator between the scanner and computer,
Old 08-21-2018, 7:25 AM
In my case the raspberry pi right?
Sent from my SM-N950F using Tapatalk
Old 08-21-2018, 7:26 AM
baj76's Avatar
yes
Old 08-21-2018, 7:28 AM
Does it matter what direction it goes in?
Old 08-21-2018, 7:36 AM
jonwienke's Avatar
It shouldn't if the isolator is a 1:1 transformer with no connection between the windings. Does the isolator have mono or stereo plugs?
Gone camping.
Old 08-21-2018, 7:38 AM
This what I'm using.
https://www.jaycar.co.nz/ground-loop...3-5mm/p/AA3086
Old 08-21-2018, 5:02 PM
Still buzzing after installing the isolator. But to be honest it maybe because I accidentally have the volume up to loud.
Old 08-21-2018, 9:57 PM
RFI-EMI-GUY's Avatar
Absolutely true. and should be a transformer type, not cheap capacitor types like sold on Amazon. You want the radio speaker output to see a transformer winding that is magnetically coupled to another winding. There should be no DC leakage between the two. The reasons are many, but primarily the new receivers have a DC coupled output that if shorted to ground or DC positive, will blow the output amp. And if it doesn't you will have lots of noise and distortion. The other benefit is that you will avoid a ground loop (HUM), and you won't damage your sound card.
If you buy a proper isolator made for stereo, you can run two receivers through it.
I don't know why this isn't stressed in the radio manuals. They just gloss over it.
"Have Spectrum Analyzer, - Will travel" "Standby for Traffic, Now Going Red"
Old 08-22-2018, 5:03 AM
Still, need some assistance please guys.
Old 08-22-2018, 5:28 AM
kma371's Avatar
Global DB Admin
Old 08-22-2018, 7:37 AM
ProScan's Avatar
Can you post a link to your feed so we can hear what kind of buzzing if it's 60 cycles.
Isolations transformers will fix the buzzing if caused by a ground loop condition. A power supply filtering problem can cause humming conditions too and can not be fixed by an isolation transformer. If you have a portable scanner, run it on batteries for a test to see if the buzzing goes away.
Also if you have a multimeter, check between the primary and secondary side don't have any resistance due to a short or miswire.
{edit} Also it's possible you are overdriving the sound input on your device. turn down the scanner audio level to see if the buzzing goes away.
Most Popular & Feature-Rich Scanner Software For The Uniden's
ProScan - RadioFeed Home Page
bob@proscan.org
Old 08-22-2018, 2:39 PM
https://www.broadcastify.com/listen/feed/28617
Humming went down when on batteries, I need to get a better power supply I guess?
Old 08-22-2018, 3:24 PM
Ok humming and buzzing still there after running on batteries.
Old 08-22-2018, 6:52 PM
ProScan's Avatar
OK, If the AC cable is disconnected from the scanner then you can eliminate a ground loop and power supply filtering problem. The only thing left is the audio cable. Make sure it's shielded and not running parallel to any AC wires.
{edit} I meant the scanner power supply. It still could be the raspberry pi power supply causing the hum
bob@proscan.org
Old 08-22-2018, 8:38 PM
Ok so the Raspberry Pi AC adapter is the official one from them, how would I isolate that?
What kinda of shielding can I get? Does it come in tape form?
Old 08-25-2018, 6:49 AM
For some reason the audio is excellent when I use the USB sound card and scanner plugged into my computer, there is a bit of hum and buzzing but not much. But when it's on the Pi its another story, what could be the issue?
Old 09-01-2018, 12:40 AM
Turns out it is the power supply going into the scanner.
