Originally Posted by slinger2424
Maybe channel is the wrong word.
If someone heads to my website....
I want them to be able to click on EMS/Fire OR Law Enforcement.
Both will be seperate individual feeds, so the fire guys dont have to listen to the LE and vise versa.
I am assuming I will need 2 scanners for this project anyway.
This can be done in two ways:
1 For each feed you have, you Embed Feed in a Web Page.
Doing this adds a player of the feed in your web site. Info is in the technicals tab for your feed page.
2 If you do not want to do #1, simply copy the URL to your feeds & post that on your web page.
Each feed will need a separate feed application & scanner.
You can use one computer for both feeds. See here:
Multiple Feed Configuration.
Does this answer your question?
