| Streaming / Broadcasting / Audio Recording Interested in putting your scanner online for others to hear? Want to listen to other radios on the internet. This forum is here for you to discuss these topics related to streaming scanners online. |
01-05-2007, 1:49 PM
Opening Ports (arc Eazystream)
ok anybody know how to PROPERLY open ports ? I am trying to setup EazyStream server for a LIVE FEED....better yet , if anybody has setup ARC EAZYSTREAM SERVER ,how did you configure the PORTS ?? I have done this so far
Running Win XP / BC246T
Installed and registered ARC EazyStream Server
Made my host at no-ip.com
Set my Firewall to let the server access the internet.
configured the program as follows:
IP/DNS :scandabands.no-ip.org
Description:South Carolina : Horry County
Audio:8300
Data:8301
City:Little River
County:Horry
State:South Carolina
Country:USA
ok I also went to network places , found my connection , properties , settings , and made the rule for opening those ports.
I have tried a the Eazy Stream Client on another computer and it will not connect....anybody tell me how to get those ports open or if I did it right?
01-05-2007, 2:15 PM
Type http://192.168.1.1 in your browser and that should bring up the settings for your router.
Once in there look for Port Forwarding. That is where you will want to open the ports. I'll take a screen shot of what mine looks like and PM it to you.
BTW those ports are different then the ones you gave me last night.
01-05-2007, 2:16 PM
yea I'm trying to get this thing working , it "ain't" happening.
01-05-2007, 3:14 PM
Silent Key Jan. 14, 2012
Run CMD and type in ipconfig/all
Under Ethernet adapter Local Area Connection find the IP Address. Then set your router as suggested by Dubbin as in this picture. I've blacked out the last parts cause yours is likely different. Of course, your ports will be different also. Note, the start and end are the same and will be your lowest number.
Frank
RR Wiki Programming Shortcuts
01-05-2007, 3:21 PM
Check section 5 in the setup manual. Refers to port forwarding settings for your router. Don't get discouraged.
01-05-2007, 3:46 PM
well I opened the ports and nothing.....
here's the info if you guys wanna try it but not sure...
8300
8301
do you guys have remote access on or off ?
01-05-2007, 3:56 PM
Sorry SDB but its still a no go. If you could give us screen shots of what you did in the router and from your no-ip settings it might help.
01-05-2007, 3:59 PM
I don't stream using this Easystream server/client thing, so I may not be that helpful, but you may need to go to Windows Firewall and let Easystream go through that port you set up.
Go to your Control Panel then Windows Firewall, select Exceptions to either add the program, or add the required port, or both.
Lexx
www.ykf.ca
01-05-2007, 4:03 PM
Lexx
www.ykf.ca
Done that but thanks , appreciated.
01-05-2007, 4:31 PM
Moderator
You may also have to create exceptions for those 2 ports in your firewall..I use Trend Micro and had to open them there as well as my router. That proved to be the step that got me up and running
01-05-2007, 4:33 PM
ScanDaBands, may I hijack for a minute and get a check by anyone on fmon.no-ip.info? 8100 & 8101. TIA
Frank
01-05-2007, 4:44 PM
No connection at 5:44pm
01-05-2007, 5:09 PM
Hmm, Open Port check is giving me Success. guess I need to do some more work.
Frank
01-05-2007, 5:38 PM
Fmon no conection at 6:37 pm EST , let me know if you figure it out man , this is about to aggravate the crap outta me.....
01-05-2007, 5:55 PM
T
Thanks, will do. I've been running off and on for some time now thinking it was working. Why, cause when checking the port with http://www.canyouseeme.org/ it only gives me success when easystream server or proscan over IP is running. When I click stop, the report returns failed.
Frank
01-05-2007, 6:43 PM
Hey folks, try mine again, I just noticed easystream setting was sending on the wrong port.
Frank
01-05-2007, 7:26 PM
Moderator
Yep, it's working. I'm connected  Audio Only, No Data
01-05-2007, 7:42 PM
what do you mean ??
01-05-2007, 7:49 PM
Thanks, wonder why no data. Oh well, I'll do some research.
what do you mean ??
For whatever reason, the port settings changed to 8300 & 8301. My port is 8100 & 8101.
Frank
01-05-2007, 8:07 PM
I give up , I've tried everything I know ,,, opened ports through my router , set it to allow within firewall , configured the software with that no-ip and mine just will not work.....something is still blocking the ports......
