As of this time, I am now providing my main scanner feed in two different manners.
1.
ProScan. Download the
ProScan client at
http://proscan.org/ProScan_Client_1_0_Build_2.zip . The client is offered free of charge. You may require Microsoft .net Framework 2.0. When you install the client it should point you to the download, install it, and continue. This is a harmless install. More info on .net Framework 2.0 can be found at
this site. ProScan offers you near realtime feed reception (about 1/2 second delay), a full display, historical data, and audio recording capability. It is to date clearly the best method for providing a scanner feed.
2.
Windows Media Player. Same video display as with ProScan but with an approximate 15 second delay from realtime. Just about every Microsoft Windows PC or laptop has Windows Media Player on it. Connect to the feed via this link, or use the Feeds drop down menu here at the message forums and connect to the top feed. Be advised that this feed is streaming to a
remote server, so I am at the mercy of its downtime. However, during the test phase, service was excellent.
The feed is now using a Uniden BC796D scanner which provides P25 reception of various entities around Cape Cod that now use that mode of communications.
I believe that this is the best combination for providing my feed. I would strongly recommend that you give ProScan a try; it is a fantastic program with some really nifty features unavailable anywhere else. I will be putting up a step by step instruction page as soon as possible, but the program is easy to install and use.
I will provide a link to the new webpage when it is built. Info will be updated shortly at the main page of this site. Thanks for your patience during this transition, and enjoy the new feed.
