Originally Posted by xusmarine1979
Hello all, I have a question that I kinda asked before. I have been doing some more thinking about this topic and was wondering. When I monitor a digital(3600) TRS, sometimes I'll pick up the cc perfectly clear but the digital TG will break up very badly. Sometimes it will be the opposite, the TG will come in perfect but the cc will be bad.
I have tried many antennas, all with and w/o the GRE amp, ATT and different locations. It seems to be the county I am in because I can actually pick up the county north of us just as well if not better than my own(at least 20 miles from county line).
I was just wondering if there was a way to even it out or a remedy I could do to solve this problem. In advance, thanks for readin and your time. God Bless.
Using:
Pro-96 w/ stock antenna
Radio Shack 800 MHz antenna
800 MHz antenna from scannermaster.com
GRE Super Amp
Stark County Ohio
It could be that the propagation from the particular channels is different.
Either different power levels or different antennas.
It could be that your scanner has different sensitivity to decoding the 2 level FSK 3600 from the 4 level C4FM/CQPSK P25/Astro signals.
It could be that the effective sensitivity of the your scanner is different on the two channels either due to something in the receiver (birdies, band edges, etc.) or due to something in the environment (Noise, IM, overloading, etc.)
