Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > System Administration and Maintenance
System Administration and Maintenance - Here is where radio system managers can discuss some of the more intricate details of managing their complex radio systems.
Old 05-01-2018, 3:49 AM
Default Decibel Products DB4140-2A VHF Notch Duplexer
I have been trying to locate a specification sheet for a Decibel Products DB4140-2A VHF Notch Duplexer. I'm interested in the frequency range, Minimum frequency separation and insertion loss. Normally I can find spec sheets for most DB Products duplexers but this one seems to be some what of a mystery.
Any information will be appreciated.
Old 05-01-2018, 6:11 AM
buddrousa's Avatar
What is the intended input frequency and the intended output frequency?
The set on ebay from AZ Highway Department range from 150-156's and are very old. We had a set that worked 300Kz they were a lot larger and very expensive.
Support your local FIRE & EMS. PRO197-18-107-668:PSR-410 X2: BC8500XLT 785d BCD436HP SDS100 BCD536HPx4 BCT346 BCD996P2 x3 BCT15x2 BCT15X2 TRX-1 TRX-2 EFJ51SL MTX8250 TK2180 MD380x4 NX5300 NX5200
Old 05-01-2018, 10:50 PM
This is another duplexer than the one on E-Bay. The output frequency is 145.210 MHZ and the input frequency is 144.610.
Thank You
Old 05-13-2018, 10:17 PM
chief21's Avatar
spec sheet here...
http://www.repeater-builder.com/ante...structions.pdf
Old 05-14-2018, 9:16 AM
Originally Posted by chief21 View Post
That is not a spec sheet.
Interoperatablity is not a technology, it is an attitude!!!
Old 05-14-2018, 3:03 PM
Thank you for the information sheet. I think this confirms my suspicion that the duplexer was constructed of individual filters and not as a set by the manufacturer. It should still work but I would be more confident if they were a matched set.
Thank you again for all your posts.
Old 05-14-2018, 4:17 PM
chief21's Avatar
I think the important distinction here is that this item is listed as a "Notch Filter" rather than a "Duplexer". A typical VHF Pass/Reject duplexer is much larger and usually consists of multiple filters. This device is a single filter and is apparently intended to notch out a single interfering signal. I don't think that I would attempt to use this with a repeater in lieu of a true duplexer (if that is your intent) as I'm not sure that you would get the necessary isolation between the transmitter and the receiver.
