Go Back   The RadioReference.com Forums > Commercial and Professional Radio > System Administration and Maintenance
System Administration and Maintenance Here is where radio system managers can discuss some of the more intricate details of managing their complex radio systems.
Old 01-19-2005, 07:02 PM
MaxTracker's Avatar
Default Trunking Protocols
I did NOT Know this - Did you?
MOTOROLA
NAME: Astro Smartnet/Smartzone
SPECS: Trunked and Conventional voice, mixed-mode analog and digital; capabile of handeling multipul bands in same talkgroup; system managment; flexible/scalable system design; data capability; conventional OTAR; simualcast; wireless console; seamless roaming.
TARGET MARKET OF PROTOCOL: Public safety and Federal Government; Utilities Industrial/Comercial
ACCESS METHOD: Analog or FDMA; 25kHz/12.5kHz channel bandwidth
MAX # channels/network: Thousands
MAX # channels per site: 28
MAX # linkable sites: 240+
SWITCH/INFRASTRUCTURE: Circut based network for Voice. trunking control, and network managment; scalable for single/multipul sites, statewide and regional applications.
DISPATCH NETWORKING: Single or multipul site dispatch; Centracom Gold elite consoles; wireling console priority.
TRANSMISSION TRUNKING: Yes
CONVENTIONAL TRUNKING: Yes
DATA CAPABILITY: --
SECURITY: DES, OFB, AES, DES-XL, DVP-XL, DVI-XL
EMERGENCY ACCESS: Yes Uses Dedicated control Channel
FREQUENCY BAND: VHF, UHF, 350Mhz, 800/821Mhz, 900Mhz
COMPATIBLE WITH WHICH PROTOCOLS?: Project 25 CAI, Analog
LIST OF MANUFACTURE LICENSEES OF PROTOCOL BASED EQUIPMENT: EFJohnson, Aeroflex
NAME: Harmoney Wireless Comm. System (iDEN)
SPECS: Digital Trunked system offering wide area dispatch, group/private calls, priority; telephone interconnect; alpha-numeric short message paging with acknowldgment; voicemail notification; all services available in one handset; portable/mobile radios; utilizes 6:1 TDMA digital tech. in 800Mhz; local remote system managment; over-the-air programming; onboard North American/International PSTN signaling protocol support.
TARGET MARKET OF PROTOCOL: Public/Private operators; Utilities; Mfg.; Campus; localized network operators
ACCESS METHOD: TDMA: 6 time slots: 25kHz channel
MAX # CHANNELS/NETWORK: 100
MAX # CHANNELS PER SITE: 77 Talk paths/13 frequencies
MAX # LINKABLE SITES: 48
SWITCH INFRASTRUCTURE: Compact PCI switching matrix with intergrated transcoding, packet duplication, and packet switching; NEBS-compliant dispatch application processor; Intergrated remote access/terminal server and ethernet switch; environmental alarm monitoring.
DISPATCH NETWORKING: Private/group call; status/messaging; priority queing; multipul call alerts; PTT-ID; isolated site operation ; wide area/network dispatch; wireless interface to Centracom Gold Elite consoles.
CONVERSATION TRUNKING: No, but hangtime is operator configurable.
DATA CAPABILITY: Alphanumeric paging; status message alert; packet data
SECURITY: CAVE38 Authentication; Ki never sent over the air; access denial
EMERGENCY ACCESS: Preemption dispatch for Emergency calls; accelerated call set-up for telephone interconnect emergency calls
FREQUENCY BAND AVAILABLE: 800Mhz
COMPATABLE WITH WHICH OTHER PROTOCOLS?: iDEN; some models compatable with GSM; can be cross-patched to other systems
LIST OF MANUFACTURER LICENSEES OF PROTOCOL BASED EQUIPMENT: Motorola; Radio Frame for air interfaces; other protocols used within infrastructure.
NAME: iDEN (intergrated DIGITAL ENHANCED NETWORK)
SPECS: High capacity Digital trunked system offering wide-area dispatch, group/private calls; priority telephone interconnect with telephony switch; Alpha-numeric short message paging with acknoldgment; voicemail notification; Intergrated mobile IP packet data; all services available in one handset; uses 6:1 TDMA digital technology in 800 Mhz band
TARGET MARKET OF PROTOCOL: Public/private operators needing wide-area multi-site coverage
ACCESS METHOD: TDMA 6-time slots: 25kHz channel
MAX # CHANNELS/NETWORK: Thousands
MAX # CHANNELS PER SITE: 143 Paths/24 Frequencies
MAX # LINKABLE SITES: 2,000 on a single network
SWITCH/INFRASTRUCTURE: Nortel DMS100 fully redundant telephony switch operating on GSM/iDEN software for Interconnect services; tandem fault tolerant computer and Cisco BPX switch for digital dispatch/packet data network; T1/E1 interface to PSTN and sites
DISPATCH NETWORKING: Private/group call; status/messaging/priority queing available; multipul call alert; PTT-ID; isolated site operation ; wireless interface to Centracom Gold Elite Consoles.
CONVERSATION TRUNKING: No, But hang time is operator configurable
DATA CAPABILITY: Fully intergrated IP Packet Data; Operator can dedicate packet data badnwidth or allow voice priority; alpha-numeric paging; mobile status messaging available; circut switched dial-up data
SECURITY: CAVE38 Authentication; Ki never sent over the air; Access denial
EMERGENCY ACCESS: Yes, with advanced feature Radio
FREQUENCY BANDWIDTH AVAILABLE: 800 Mhz
COMPATABILE WITH WHICH OTHER PROTOCOLS: iDEN, some models compatabile with GSM can be cross patched to other systems
LIST OF MANUFACTURE LICENSEES OF PROTOCOL BASED EQUIPMENT: Motorola; Radio Frame for Air interfaces; other protocols used within infrastructure.
MA-COM Wireless Systems-
SPECS: Trunking: Continously available control channel; group, individual, emergency calls; flexible group hierarchy; mixed-mode operation; (analog/digital/data calls simualtaniously) telephone interconnect; data; status messaging; priority queing; late entry; console pre-empt; fault-tolerant with distributed processing; short message service; OTAP
TARGET MARKET OF PROTOCOL: Public safety/service; utilities; military; government; industrial; SMR
ACCESS METHOD: FDMA
MAX # CHANNELS/NETWORK: 11,520
MAX # CHANNELS PER SITE: 24
MAX # OF LINKABLE SITES: 480
SWITCH/INFRASTRUCTER: Intergrated Multi-site console switch; fault tolerant design with distributed processing; IP, analog, modem, and/or T1/E1 interfaces; switch conectivity for sites, consoles, conventional phone interconnect, log, recorders, data, billing and correlation unit, CAD
DISPATCH NETWORKING: Wide area/Dispatch network; geographical user interface; customized layout; intergrated paging; status messaging; call tracking; auxiliary inputs/outputs; various user interface options (mouse, trackball, touchscreen, keyboard)
TRANSMISSION TRUNKING: Yes, Calls assigned to any available working channel
CONVERSATION TRUNKING: Yes, User defined hang-time allows the same channel to be utilized for the entire conversation.
DATA CAPABILITY: Radio-to-Radio, Radio-to-Network, and Network-to Radio data; all site channels support voice or data on a per call basis; data only channels are partionable.
SECURITY: Digital Voice Security provided in M/A-Com's ProVoice offering EDACS Security Key (ESK) protects control channel against un-authorized users and prevents radio programming from being altered.
EMERGENCY ACCESS: Yes, from any radio or console; programmable to remain keyed for a user defined period of time after the emergency is activated.
FREQUENCY BAND AVAILABLE: 800 Mhz, 900 Mhz, UHF, VHF.
COMPATIBLE WITH WHICH OTHER PROTOCOLS: Can be interfaced to other systems; IP; P25; CAI.
LIST OF MANUFACTURE LICENSEES OF PROTOCOL BASED EQUIPMENT: Console vendors: Avtec, Orbacom, Zetron; logging recorders: Dictaphone. Nice, Mercom.
SPECS: TDMA digital voice and Data; end to end IP data; supports cellular-like base stations architecture with roaming and hand off; 4 talk paths in 20 kHz channels; over the air reprogamming and reprovisioning; inteligent in-band vehicular repeater; pole top filter sites; short message service; OTAP; remote software downloads.
TARGET MARKETS OF PROTOCOL: Public safety, Transit, Transportation, Utility.
ACCESS METHOD: TDMA with Control Channel Functionality embedded in all working channels
MAX # CHANNELS/NETWORK: 36,000+
MAX # CHANNELS PER SITE: 31
MAX # LINKABLE SITES: 6,000
SWITCH/INFRASTRUCTURE: COTS UNIX-Based hardware running VoIP switching software; voice and data routing uses COTS IP routing equipment.
DISPATCH NETWORKING: IP consoles: wide-area network dispatch; GUI customized layout; intergrated paging; status messaging; call tracking; aux. inputs/outputs; various user interface options (mouse, trackball, touchscreen, keyboard); Interoperability gateway.
DATA CAPABILITY: Subscriber devices act as IP network nodes; serial line IP connection to data terminal; aggregate airlink data rate 19.2 kbps; radios support full duplex data.
SECURITY: AES Voice and Data Encryption available; digital air interface protocol protects against casual eavesdropping; system supports OTAR.
EMERGENCY ACCESS: Yes, Includes Priority Preemption
FREQUENCY BANDS AVAILABLE: 800 Mhz, 700 Mhz; 900 Mhz (under devolopment)
LIST OF MANUFACTURER LICENSEES OF PROTOCOL BASED EQUIPMENT: Subsriber: M/A-COM: Consoles: Avtec, Orbacom, Zetron; Logging recorders: Dictaphone, Nice, Mercom.
SPECS: Digital Trunking System; IMBE with Improved forward error correction; Continously available control channel; Fast channel access; Group, individual, and Emergency calls; mixed mode operations (analog/digital/data calls simultaniously); Telephone Interconnect; data; status messaging; priority queing; late entry; console preempt; fault tolerant with distributed processing; short message service; OTAP.
TARGET MARKET OF PROTOCOL: Public safety/service, utilities, military, government, industrial, SMR.
ACCESS METHOD: FDMA
MAX # LINKABLE SITES: 480
SWITCH/INFRASTRUCTURE: Intergrated multisite/console switch; fault-tolerant design with distributed processing; IP, analog, modem, and/or T1/E1 interfaces; conectivity for sites, consoles, conventional phone interconnect, logging recorders, data, billing/correlation, CAD.
DISPATCH NETWORKING: Wide-area network dispatch; geoghaphical user interface; customized layout; intergrated paging; status message; call tracking; auxiliary inputs/outputs; various user interface options (mouse, trackball, touchscreen, keyboard)
TRANSMISSION TRUNKING: Yes, calls are assigned to any available working channel.
CONVERSATION TRUNKING: Yes, user defined hang time allows same usage for entire conversation; generally less efficient than transmission trunking.
DATA CAPABILITY: radio-to-radio, radio-to-network and network-to-radio data; all site channels support voice/data on a per call basis for maximum effency; data only channels are partionable.
SECURITY: All digital air interface; digital voice (IMBE) with DES encryption; multipul encryption keys; FIPS-140; EDACS Security Key (ESK) protects control channel from unauthorized users/radio programming from being altered.
EMERGENCY ACCESS: Yes, from any radio/console; programmable to remain keyed for a user-defined period of time.
FREQUENCY BAND AVAILABLE: VHF, UHF, 800 Mhz.
COMPATIBLE WITH WHICH OTHER PROTOCOLS?: ProVoice systems can be interfaced to other systems; IP; P25.
LIST OF MANUFACTURE LICENSEES OF PROTOCOL BASED EQUIPMENT: Consoles: Avtec, Orbacom, Zetron; Logging recorders: dictaphone, Mercom.
European Telecom.
Standards Institute (ETSI)
AKA: Trans-European Trunked RAdio
SPECS: Fully digital, four slot TDMA technology providing group calls, individual calls, full-duplex cellular style telephony services; circut switched and packet data at rates up to 28.8 kbps; fast call set-up<500ms
TARGET MARKET OF PROTOCOL: Public safety, utilities, transport, local government and ESMR-type systems.
ACCESS METHOD: 4-slot TDMA
MAX # CHANNELS/NETWORK: virtually unlimited
MAX # CHANNELS PER SITE: Vendor dep., >30 (typically)
MAX # LINKABLE SITES: Vendor dep., No theoretical limit
SWITCH/INFRASTRUCTURE: Vendor dependant; centralized switching, distributed switching, and switchless IP architectures are offered.
DISPATCH NETWORKING: Not standardized, vendors have open API's.
TRANSMISSION TRUNKING: Yes.
CONVERSATION TRUNKING: Yes.
DATA CAPABILITY: circut and IP packet data 7.2-28.8kbps.
SECURITY: Authentication, Air interface encryption, static and dynamic keys, end-to-end encryption.
EMERGENCY ACCESS: Preemptive emergency call (standard)
FREQUENCY BAND AVAILABLE: 370-400 Mhz, 410-430 Nhz, 800 Mhz.
COMPATIBLE WITH WHICH OTHER PROTOCOLS: TIA project in-hand for compatability with P25.
LIST OF MANUFACTURE LICENSEES OF PROTOCOL BASED EQUIPMENT: Ascom Systec, Atmel, Avitec, BESCom, Cleartone, M/A-COM, CML, Damm, Electrobit, ETELM, Frequentis, Icom, Motorola, Niros, Nokia, OTE, Rohde & Schwarz, Rohill, Sepura, Sigma, Sinclair, Teltronic, Thales, Zetron, others.
Trident Micro-Systems-
SPECS: Wide-Area Networking (WAN); Automatic roaming between sites; mobile kill/stun; electronic serial number; mobile ID; No control channel required; Interconnect; Selective call (unit-to-unit private calling)
TARGET MARKET OF PROTOCOL: Networked/single-site SMR, utilities, Single and multisite private wireless.
ACCESS METHOD: Subaudible Digital Signaling; 12.5 kHz/25 kHz FM.
MAX # CHANNELS/NETWORK: 3,810
MAX # CHANNELS PER SITE: 30
MAX # LINKABLE SITES: 127
SWITCH/INFRASTRUCTURE: Supported by Trident NTS digital network infrastructure; NTS operates with a distributed networking architecture.
DISPATCH NETWORKING: Multisite wide-area dispatch network calling supported; call set-up times<400ms.
DATA CAPABILITY: Yes, supports a wide variety of third-party applications and equipment.
SECURITY: High level of access security through unique ESN assigned to each subscriber unit by radio manufacturers; voice privacy through subscriber unit encryption available.
FREQUENCY BAND AVAILABLE: VHF; 220 Mhz; UHF; 700/800/900 Mhz.
COMPATIBLE WITH WHICH OTHER PROTOCOLS: NTS Can facilitate interconections with radios of other protocols.
LIST OF MANUFACTURER LICENSEES OF PROTOCOL BASED EQUIPMENT: Aeroflex, ADI, ComSpace, Vertex Standard; Motorola; Kenwood; Icom; Ritron; Scholer-Johnson; Tait.
SOURCE: RadioResource MissionCritical Magazine
January-February 2005
"Specs Guide 2005"
http://www.mccmag.com
Old 01-20-2005, 05:28 PM
DaveNF2G's Avatar
How about crediting your source?
The info looks just like that published in the annual Buyer's Guide that just came out from "Law Enforcement Technology" magazine.
David T. Stark
Educator - Criminal Justice, Sociology
NF2G WQMY980 KYR7128
"I'm everywhere, Focker!"
Old 01-23-2005, 11:26 PM
MaxTracker's Avatar
I sure ment to Dave, But it was late and I was tired!
That piece came from: Mission Critical Magazine (Formerly Radio Resource Magazine) Yes, it is the 2005 Buyers Guide. And WoW, was that some informing stuff to me, I had never known how complicated some of that was. Nor did I know how similer alot of the protocols were, or what 1 or changes make EDACS differant from Open Sky or ProVoice.
I didn't get to put up the Differant types of LTR, Nor do I want to attempt it. I blurred my Eyes to death on the Motorola and M/A-COM pieces. But, If anyone gets a copy of that guide it is amazing the differances and technical specs that surround LTR, Multi-Net, Passport and MPT-1327 Systems.
Old 01-25-2005, 03:31 PM
I don't understand something, they said that ProVoice is a trunking system.. when we know that is a protocol to send vocoding audio on the air... ?
