Go Back   The RadioReference.com Forums > Site Administration Forums > System-wide Administration
System-wide Administration - Support for issues related to subscriptions, server connectivity and commentary, and layout usability. Area specific content should be posted to its applicable forum below.
Old 12-26-2008, 8:31 PM
Default Custom tables
Since there are probably a few zillion new Radio Shack / GRE scanner owners now, it would help if the table data for non-standard and rebanded trunk systems was updated to include the info needed by these scanners, especially low and high channels. It wasn't obvious to me that the low channel is the same as the offset, or that a P25 system might still be programmed as MOT VHF/UHF. Not sure how a newbie could tell what the high channel should be, unless they're familiar with the band in question.
Thanks.
Old 12-26-2008, 10:35 PM
fmon's Avatar
Silent Key Jan. 14, 2012
http://wiki.radioreference.com/index.php/Win96 Look at bottom of this Wiki page. Tables will be the same.
These two tables were developed by Wayne H and used in the sample on Wiki page.
http://www.radioreference.com/forums...d.php?t=100208
The four software's for the new GRE/Radio Shack scanners will also automatically set tables when the user needs them.
Frank
RR Wiki Programming Shortcuts
Old 12-27-2008, 8:03 AM
DaveNF2G's Avatar
Another way to acquire full tables is to run Pro96Com. It will display all of the necessary information on the Site Information tab after accumulating it from the control channel data.
David T. Stark
NF2G WQMY980 KYR7128
