Go Back   The RadioReference.com Forums > Site Administration Forums > System-wide Administration
System-wide Administration Support for issues related to subscriptions, server connectivity and commentary, and layout usability. Area specific content should be posted to its applicable forum above.
Old 03-15-2009, 10:53 PM
Default RR freq. in personal website
Has anyone added RR to their website? Id like to see it before I insert it in mine. Thanks, Bill
Bill Lakin
Old 03-15-2009, 10:57 PM
NeFire242's Avatar
When you say add do you mean like link, or an actual API or SDK involvement?
Old 03-15-2009, 11:23 PM
n5ims's Avatar
Check the WIKI...
API --> API - The RadioReference Wiki
Old 03-16-2009, 12:17 AM
OH/WV DB Admin
Send a message via MSN to mtindor
There are plenty of examples in the Wiki...
check this one: Licking County, Ohio - The RadioReference Wiki
That should give you an idea of how it would be presented should you include it in your own pages. Obviously the Wiki link was created by an individual, but it incorporates some data from the RRDB in the same way the XML-API would.
mike
Old 03-16-2009, 08:11 AM
Wiki Admin
Mike, I'm afraid you are mixing apples and oranges and coming up with grapefruits, hi. The example you gave uses the wiki extensions to place data on a wiki article (which is internal to RR), not someone's website. As mentioned by a couple of other folks, you would use the API to place data on a personal website. Here's an example from the Scan Virginia website...
ScanVirginia Database Eastern Virginia Regional Communications
73 Mike
Old 03-16-2009, 09:17 AM
blantonl's Avatar
Administrator
Here are the top 10 domain users of RadioReference content
The Extra Alarm Association
Tennessee Scanner and Ham Radio Frequencies by N4YEK.
http://www.scannerdesk.com
Western North Carolina Scanner Club - Scanning WNC Since 1999
ScanMemphis
Freq Of Nature
ScanVirginia Your Local Source For Live Information
scanningmetrorichmond.info
http://smerg.org/radio/
Scan East Texas
Lindsay C. Blanton III
President - RadioReference.com LLC
Facebook: RadioReference | Twitter: @RadioReference
Old 03-16-2009, 10:23 AM
OH/WV DB Admin
73 Mike
Mike,
I'm aware of the differences. I didn't have a specific webpage to demonstrate with, and the Wiki extensions that incorporate the data into the Wiki I think do essentially the same thing - so I gave that as an example.
Here is an example if somebody wants to look at a totally generic dump of RRDB data into a plain HTML page on a website:
http://www.ovscan.com/example.html
Compare that to the wiki link I sent above and I think you'll see the data looks virtually identical whether it be incorporated into a wiki article using wiki extensions or whether it be incorporated into a webpage using the XML-API. I think my original example was apropros.
Old 03-17-2009, 04:04 AM
NeFire242's Avatar
Wow, that was only like 3 lines of code behind that, I can see the advantage especially on an ever-changing system, etc.
Old 03-17-2009, 10:57 AM
WouffHong's Avatar
Default Thoughts on import.. and questions.. ;-)
I also cranked one up last night at LOCAL SCANNING INFORMATION , but would like to NOT have the input frequencies showing (for obvious reasons), yet they are there even when the page that was used for selection had input frequencies DE-selected.
Also on other pages, like for a large city or some counties, I can get all the the groups and ID's, but cannot get or find the Import-ID code that will show the EDACS frequencies - there are "Import" ID's for everyhing BUT the frequencies section. Perhaps there is a technical reason for that? or Policy? :-0>
Or just not digging down far enough..??
Help kindly accepted! :-) ;-)
Tom
Old 03-17-2009, 12:12 PM
OH/WV DB Admin
Tom
Tom,
I'm not sure I'm understanding you correctly.... But if I am, take a look at the RadioReference Remote Render API page (linked off of the RR homepage).
Also - see my example - http://www.ovscan.com/example2.html
If I'm understanding you correctly, you want to do one of the two things in my example. If that is not correct, please provide more detail including the system you are wanting to display data from.
Old 03-17-2009, 12:41 PM
WouffHong's Avatar
Default Q&A session :-)
OK - I have been using the API page as a "bible" for the process, but perhaps I missed something ; Let's take, for example, Orange county/Orlando area:
Scanner Frequencies: Orange County Trunking System, Orlando, Florida
There is no place *I* can find that will give me the ID to display the "System Frequencies" on a remote page, the "Talkgroup" section has the blue triangle leading to an ID for the remote page, but "System Frequencies" does not. Even tried the "-205" SID as "siteId" but no joy. NO problem on the few others I have linked to, but why Orange County?
That help my query, i.e. to define it better? :-)
Tom
Tom,
Old 03-17-2009, 01:37 PM
OH/WV DB Admin
Tom,
I tried it and it worked fine. First I displayed just Zellwood - listed as site 002 (SiteID = 202 = UniqueID for Zellwood). Then I displayed all sites (Sites = 205 = SID).
http://www.ovscan.com/example3.html
The code:
http://www.ovscan.com/example3.txt
Let me ask you this -- did you sign up for a key? You have to use a key that is specific to your site. For instance, you can't post my code in example3.txt into an HTML file on _your_ website because it won't work. You must obtain a key first per the instructions, and that key has to be tied to your site.
Old 03-17-2009, 01:41 PM
OH/WV DB Admin
<snip> - duplicate
Old 03-17-2009, 01:43 PM
OH/WV DB Admin
Ex: In my "Account" off of the main RR page, if I click on API, I see:
http://ovscan.com 28702560 Active 56
So the key 28702560 is tied to http://ovscan.com. If it gets served from www.isuckathtml.com, it won't work.
Old 03-17-2009, 01:53 PM
OH/WV DB Admin
If there are multiple sites in the system (such as the one you referenced), if you want to get the uniqueID for that, then click on the site, such as 002 (2) Zellwood .
Then you'll see:
Unique DB Site ID: 202
Use that 202 ID in the properly formatted line that ends with SiteID=
If you want to display all the sites, use the properly formatted example in the "bible" and for the SID use 205 (you already figured that out) -- SID=205
Old 03-17-2009, 03:54 PM
WouffHong's Avatar
Cool Dumb and Dumber.. ;-)
Mike - Apologize for taking your time - I intially was working with a link that had a mistake, but as a "search and destroy" typist, I copy the link-html to the next trial line and propagated the "sitid" parameter along with the rest.. changed to "siteId" (capital "I")
and off we went.. Hoo..boy.. One CAN get stuck deep in mud, no? :-))
THANKS for your help - looking carefully at your examples made that capitalization eror pop out!
Tom
Dumb and Dumber
Then you'll see:
Old 03-17-2009, 04:55 PM
OH/WV DB Admin
Tom
Dumb and Dumber
Tom,
Glad I could help. Nothing dumb about the problem you were having. Sometimes we all need a second set of eyes cuz the ones we have just aren't seeing things. Been happening to me ever since hit 40 rofl.
Old 03-17-2009, 05:31 PM
WouffHong's Avatar
Tom,
And I am 70+ with shaky vision!
Thanks again, Mike
Tom
w4nov.us
Old 03-17-2009, 05:35 PM
AlmostHandy's Avatar
Send a message via Skype™ to AlmostHandy
That is Awesome. I had no idea you could link to RR like that. When the RR DB updates, do those pages update automatically?
Old 03-17-2009, 05:56 PM
OH/WV DB Admin
Yes it does. Using the XML API causes the latest data to pulled directly from RR's database and inserted into your own site.
Similar Threads
Albuquerque International Balloon Fiesta Mick New Mexico Radio Discussion Forum 12 10-09-2008 04:31 PM
input trunking from rr website to pro97 using win97 jim0680 Scanner Programming Software 1 06-16-2008 08:31 PM
Personal Radio Association Membership Drive jwilkers Tavern Archives 13 12-09-2005 01:42 PM
Personal Radio Association (PRA) Membership drive. jwilkers Tavern Archives 17 08-01-2005 12:06 AM
ND Police Scanner Freq website Guardman North Dakota Radio Discussion Forum 3 06-20-2004 01:32 PM
