Go Back   The RadioReference.com Forums > Site Administration Forums > System-wide Administration
System-wide Administration Support for issues related to subscriptions, server connectivity and commentary, and layout usability. Area specific content should be posted to its applicable forum above.
Old 10-09-2009, 01:06 PM
3mary2's Avatar
Question Screen Size
Good Morning
A while back there was a discussion on changing the size of the program to match my screen size. I have looked until I have a headache and cannot find anything. I have a new screen which measures 16" across or 20"corner to corner. I think I remember an article stating how to fix the size so as not to have to use the bar at the bottom to scroll back and forth. If anyone remembers this article could you point me in the right direction.
THANK YOU in advance for your time and consideration
Old 10-09-2009, 02:07 PM
MFD4305's Avatar
Default A Key Combination
'Ctrl' plus '+' will increase the size of the image to better fit your screen; 'Ctrl' plus '-' will decrease the size. I don't believe there's a way to achieve an exact fit, but I'd be happy to learn if someone else does....
Remember: no matter where you go - there you are!
[Buckaroo Bonzai]
Old 10-09-2009, 02:08 PM
3mary2's Avatar
Thank You very much it works great!! :-)
Old 10-09-2009, 02:13 PM
3mary2's Avatar
How do you make the font bigger? Or will that throw everything out of place again? When I print from RR it comes out smaller than the screen size THANK YOU very much for all your help
Old 10-09-2009, 02:48 PM
qlajlu's Avatar
Press the CTRL key and roll you mouse wheel at the same time.
EDIT TO ADD: I dunno. Maybe that won't do it. I just tried it and all it did was adjust my screen size. Not sure about what the relationship between what you see on the screen and what comes out of the printer may be.
If you can read this, thank a teacher - If you are reading it in English, thank a veteran.
Drive no faster than your guardian angel can fly.
Time has a way to corrupt everything.
Old 10-09-2009, 02:58 PM
MFD4305's Avatar
Default I'd Suggest...
... that you try "print preview" before you actually print (easy if you're using FireFox for your browser) then size the image to fit the page.
[Buckaroo Bonzai]
Old 10-10-2009, 10:57 PM
bezking's Avatar
Moderator and DB Admin
Send a message via AIM to bezking
Rolling the scroll wheel has no bearing on print size. To control print size in Firefox, go to File -> Page Setup, uncheck "Shrink to Fit Page Width," and mess around with the scale (100%) is original size, and see what works for you.
--bezking
Moderator, NY-NJ DBA, Wiki Admin
bezking @ radioreference.com
Old 10-13-2009, 10:27 PM
mciupa's Avatar
If using IE, you could click on View on the classic tool bar. Select Text Size and choose between
Largest
Larger
Medium
Smaller
Smallest
. . . whatever works for you.
