Go Back   The RadioReference.com Forums > Site Administration Forums > System-wide Administration
System-wide Administration Support for issues related to subscriptions, server connectivity and commentary, and layout usability. Area specific content should be posted to its applicable forum above.
Old 03-12-2013, 12:21 AM
kayi4cle's Avatar
Default Home Page Issue
When I click on the Home Page, I see it for a second and then I get a white page with nothing on it. I was wondering if anyone else is experiencing this. I haven't visited the Home Page in awhile, but this has never happened before. I hope this is the right forum for this; if not, kindly move it to the correct place. Thanks so much for your help.
I just checked again before posting, and it just goes to a totally white page, rather than seeing it for a second before becoming blank.
Old 03-12-2013, 12:59 AM
kf4uuz's Avatar
Are you sure you're logged in?
KF4UUZ
Old 03-12-2013, 1:11 AM
I'm having the exact same trouble with the RR home page since Sunday evening. It appears for a half second then goes blank.
Old 03-12-2013, 1:26 AM
I've been getting the same thing. Looks like somebody slid a redirect in...
Here's the source code from the home page -
<script language="JavaScript" src="http://82116.statistic-online.com/stat_engine.js?v1"></script>
Old 03-12-2013, 1:56 AM
W8RMH's Avatar
Thumbs up No problems here.
No problems here.
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 03-12-2013, 3:30 AM
Default Same issue
It appears to be related via Yahoo. Google goes right through.
My norton has been giving me a warning for the last 3 days that it's blocking an attack named "redexploit".
Old 03-12-2013, 3:44 AM
RonnieUSA's Avatar
I have the same problem, if using IE 10, you get a glimpse of it for about 2 seconds, and then it is just a blank white page.
Everything is fine using Firefox.
Radio Shack Pro-197 - Uniden BCT15X
Win500 - ARC500 - FreeScan - ARC-XT-PRO - ID Tracker III
Old 03-12-2013, 4:17 AM
Wiki Admin Emeritus
I saw that briefly yesterday morning, but not since, while at work. We're using IE9...Mike
Old 03-12-2013, 7:05 AM
mfn002's Avatar
Same here, with IE10. I tried repeatedly yesterday and the homepage went blank after 2 seconds.
It's working fine now, however.
Michael
BC396XT*BC996D*BCD996XT*PSR500
XTS5000 M2 VHF*ICOM IC-R71A*STEWART-WARNER R-392/URR
SHSU '13
Old 03-12-2013, 9:22 AM
Rt169Radio's Avatar
Im having the same problem, it will sometimes go blank, and then sometimes it will work.
Old 03-12-2013, 9:52 AM
I am having same problem. Can't access home page. I got here by bypassing and going to login. I have ie 8. I tried on my laptop with windows 7 and ie 9 ...same deal. Something about jquery.min.js. Please fix this. Thanks
Old 03-12-2013, 10:37 AM
I think I fixed it. I logged on went to Google search. Added the home page to favorites which over wrote the old link. Now it goes to home page every time. CRazzzzzy
Old 03-12-2013, 11:06 AM
loumaag's Avatar
Moderator
Arrow
I think there was in issue with some java script on a specific ad site. That ad did not load every time so the issue was intermittent. I am not sure but Lindsay took the site down for about 10 minutes this morning and I have not been able to reproduce the problem since, so he probably took care of it.
Old 03-12-2013, 12:44 PM
kayi4cle's Avatar
Yes, it loads in now. I haven't tried logging in over there, but will do that as soon as I log off from this part of the site. Thanks so much!
To kf4uuz, thanks for your help, but I believe you have to log on to that page totally separately from the forums section. And that can't be done if the page isn't loading in. Hopefully that is fixed now.
Old 03-12-2013, 1:00 PM
kayi4cle's Avatar
It is working fine now. I like to check it periodically to see which of the systems I am tracking have the green highlighted updates. That is a really great feature which saves me a lot of time in keeping up with local changes. Thanks Lindsay for your outstanding support!
Old 03-13-2013, 9:31 AM
Default Blank page is back (IE)
When I clicked on the RR Home Page link using IE10 just now I got a blank page. No warning from Norton about a Red Webkit Attack, just a blank page.
Bud
Pro-34/Pro-97/PSR-500
Old 03-13-2013, 9:44 AM
I had it working yesterday, but as bud says it's Baaaaack to messing up again. Win xp and ie 8.
Old 03-13-2013, 10:23 AM
Default Basic info
Here's what I am seeing.
Chrome, Firefox and Safari display properly and I don't get a blocked message from Norton. I get the blank screen and Norton notification when using IE10.
My system is running Win7 (all updates applied) the latest version of IE 10 and the latest version of Norton Anti Virus (updates every couple of minutes).
I'm getting the quick flash of the home page, then a blank screen followed by an alert message from Norton.
Here's the short version from Norton:
Web Attack: Red Exploit Kit Website 2
infocream.com/wrlc.htm 67.19.86.2, 80
Each time I attempt to access the RR Home Page with IE 10 a different url and ip is listed in the Norton Event log.
I hope the following helps you resolve this issue.
Bud
Old 03-13-2013, 10:38 AM
RonnieUSA's Avatar
I also still get a blank page using IE 10 on Windows 8, up to date as of this morning, using the latest Avast.
Old 03-13-2013, 10:39 AM
A longer discussion about the Red Exploit messages is in this other thread:
Malicious Site Warnings
Hope this helps,
73 QDP
[106/2SRA]
