Go Back   The RadioReference.com Forums > Site Administration Forums > System-wide Administration
System-wide Administration - Support for issues related to subscriptions, server connectivity and commentary, and layout usability. Area specific content should be posted to its applicable forum below.
Old 06-05-2018, 10:47 AM
JLM7424's Avatar
Default Trunking questions and discussion area ?
I swear their use to be a Trunking discussion area, can we have one ?
or can i please be directed to where i should ask for help on a nxdn trunking /system questions
trying to determine if a found frequency is NXDN single freq or trunk
Thank you Matt.
Signal Interceptors| SDS100 / BCD536 /436HP's ProV~DMR~NXdn | BCD396XT | PSR600 |
Old 06-05-2018, 10:52 AM
jonwienke's Avatar
The Uniden technical support forum would seem to be an obvious venue...
Old 06-05-2018, 11:07 AM
JLM7424's Avatar
I posted this here for admins to answer thanks
Old 06-05-2018, 11:09 AM
KE4ZNR's Avatar
KE4ZNR@radioreference.com
Originally Posted by JLM7424 View Post
I posted this here for admins to answer not a rude member thanks
He was not being rude but trying to help you understand that the Uniden Tech support forum is indeed the correct forum for questions about operating a Uniden BCD536HP.
https://forums.radioreference.com/uniden-tech-support/
Marshall KE4ZNR
NC/SC Forum Moderator/Database Administrator
Frequently Asked Questions
Forum Rules & Guidelines
@KE4ZNR on Twitter
Old 06-05-2018, 11:11 AM
JLM7424's Avatar
Marshall KE4ZNR
my question is not uniden specific , my Original post has been revised ,what happened to the trunking forum ?
Old 06-05-2018, 11:19 AM
JLM7424's Avatar
I apologize for my previous response the "Obvious " just seemed Deming to me , sorry matt.
Old 06-05-2018, 11:25 AM
UPMan's Avatar
Uniden Representative
As the question pertains to how it should be programmed into a BCDx36HP, it still is appropriately placed in the Uniden forum, as no other manufacturer's scanner trunk tracks NXDN.
Uniden Product Ninja
Personal Blog
For better help, tell us specifically what you are trying to scan.
jonwienke's Avatar
Actually, it is, because the answer to your question will be completely different depending on the model scanner you are using.
Uniden has a programming option called One Frequency Trunked that can be used to identify talkgroups and other trunking info on an unknown frequency. Whistler requires you to program unknown frequencies as conventional digital. The Uniden SDS-100 has additional options that can identify the system and site IDs of a trunked system from a Close Call hit, allowing you to program the frequency directly into a trunked system site without any intermediate steps.
Old 06-05-2018, 11:28 AM
JLM7424's Avatar
I give up ADMIN delete this thread if you can thank you .
Old 06-05-2018, 11:32 AM
JLM7424's Avatar
Thank you paul
Old 06-05-2018, 11:38 AM
JLM7424's Avatar
Please Delete this Thread if possible Thank you , sorry for the confusion
Old 06-05-2018, 11:41 AM
UPMan's Avatar
When you do ask, there, give specifics (what frequency(ies)), RadioReference database page if it is in the dB, etc. I've taken to mostly ignoring posts for help where no useful diagnostic info is provided.
Personal Blog
Old 06-05-2018, 11:48 AM
JLM7424's Avatar
Ok thank you for the advice well received .
